HondaAccord Forums - Photo Galleries - Create an Account
Go Back   Honda Accord Forum - Honda Accord Enthusiast Forums > General > General Tech Help
Reply
Thread Tools Search this Thread
Old 11-06-2009, 11:10 PM
slimlocon3 slimlocon3 is offline
Default Engine knocking
I went to replace the grommets on the lower part of the rocker arm assembly for the spark plug tubes and i didnt let the tension off correctly and now my cylinder one exhaust lifters are knocking what do i do to fix this i have a 96 2.2 non vtec
Register now for free or log-in if already registered to remove this ad!
Old 11-07-2009, 12:20 AM
kris_loehr kris_loehr is online now
What did you do to let the tension off?
Do a search for Valve springs Clatter posted by myaccord93. It should help.
Chris
__________________
Chris lower
Old 11-07-2009, 10:14 AM
deserthonda's Avatar
deserthonda deserthonda is offline
i would remove the valve cover, make sure that rocker arm are properly over the valves,,if all is ok,, chk the valve adjustment
if when you put it together and you installed it so the rocker arm was not properly over the valve and you ran the car,,could bent a valve ...But first things first, chk over your work , make sure akk is put back on properly and everything is tight
__________________
Take a look in the DIY section before asking for help.
Always Diagnose First,,, Before Replacing Parts.
Old 11-08-2009, 11:45 PM
ok i put the motor at top dead center for cyl. #1 and i tightened the rocker arm assembly down the correct way and then i check and adjusted the valve clearance and it ran smooth for about 30 secs and started knocking again i'm pretty sure i bent a valve so I'm thinking of just buying a rebuilt head any other suggestions?
Old 11-09-2009, 12:46 AM
You may want to do a compression test to verify a bent valve but Number one cylinder comes up twice for TDC. You need to have it on the compression stoke. All the rockers should have been at rest to make the adjustment and the cam sprocket has something to indicate this also. You may want to check out the manual. You mentioned taking off tension. A bent valve normally would happened if you tighten down the rocker adjustment well beyond specs.
__________________
Chris lower
Reply
Tags
22, 96, accord, adjustment, engine, honda, knock, knocking, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
