Replacing/Cleaning IAC Valve - 98 Accord EX
Old Dec 23, 2008 | 06:42 PM
Brian R's Avatar
Default RE: Replacing/Cleaning IAC Valve - 98 Accord EX
ORIGINAL: finch13
EVAP codes usually mean that you didnt tighten the gas cap 3 clicks, I've gotten that before too. If it's persistent, it acutally may be the EVAP canister haha.
And don't worry, the previous owner of my car (bought in April) said the CEL has been on for 7 years. Runs and drives great, especially after cleaning the manifold.
As far as doing things right, if you don't want to tackle cleaning the manifold yet, then don't do something youre not comfortable doing. You may as well just remove the EGR valve, clean out the ports with carb cleaner the best you can (you can see the rectangular opening on the right travel to the intake manifold). If you destroy the gasket, buy a new one or just make one with the RTV.
The original owner actually warned me about the evap code, and told me the dealer told him it was due to the car not having a stock Honda gas cap. I guess it is picky about venting?
I am still getting the EGR code, even with the new valve... Do you think cleaning out what I can access by only removing the valve is going to be enough to keep my Honda happy?
I really appreciate all your help!
Old Dec 23, 2008 | 08:00 PM
ORIGINAL: Brian R
What I think happens with the gas cap is, if its not tight enough or letting out to much pressure, the car thinks that the EVAP canister is leaking because the vapor pressure in the tank is too low.
With a new EGR valve, the only thing you fixed was the valve opening or not, the passageway to the and from the valve can be easily clogged with carbon soot and thats what usually goes wrong.
Your welcome for the help! I like to be on here helping and if it saves someone some money or a big headache, then great!
Old Mar 18, 2009 | 07:55 AM
hfddd
Default clear EGR valve ports accord 1998 lx v4
Hi
How do you clean the egr valve and ports on a 4 cylinder honda accord 1998 LX?.My friend is mechanic but he never clear a EGR valve ports before. if you could please give us procedural advice on how to clear EGR valve ports. including a diagram of there locations.And pictures can be very helpful.
Thank you
Old Mar 18, 2009 | 11:45 AM
There is only 1 EGR passageway cast into the intake manifold for the EGR. Just take off the upper intake manifold and the EGR valve, and you will be able to see the passageway.
Old May 29, 2009 | 07:33 AM
larrypac99's Avatar
Default sensor readings
Can anyone tell me where to find the specs for all of the fuel sensors such as IAC,TB,etc. I have a friend who is a good mechanic, but without knowing what the readings are supposed to be he cannot do much. My 99 has some idling issues and I would rather not drive 50 miles to the Honda dealer and pay $75/hr. A shop manual would be great if I could get one cheap/free online.
Larry
Old Jun 1, 2009 | 06:54 AM
The pdf manuals are linked in the DIY section, but I think they don't go as new as 99.
www.helminc.com is the absolute best manual, but pricey. But it'll pay for itself with one hour shop labor.
You might be able to find one of those Helm books at a public library??
Old Jul 30, 2010 | 01:39 AM
  #17
Max G's Avatar
Default Location.
IM not even sure where it is located? Do you know where it is located? I have the V6 3.0L
Old Jul 30, 2010 | 01:41 AM
  #18
Max G's Avatar
Default Location!
Can you tell me where itd be located on a V6 Model? I cant seem to find it. Can you maybe post a pic????
Girlsplay basketball
Sep 8, 2011 08:24 PM
Silver98V6
Apr 20, 2011 10:21 PM
jamrock
May 20, 2010 06:45 AM
markrb
May 1, 2008 12:34 AM
