Leaking Power Steering Pump
Old Nov 22, 2009 | 09:24 AM
Randy367's Avatar
Yeah I've check autozone and they sell the kit for $17 but I'll have to order it. As far as I can tell it has everything there. The PS pump breakdown photo is from Majestic Hondas website. I guess that's better then $100 for a rebuilt PS pump. Will do that next weekend. Now is there anything I should know before I tear apart the PS pump.
Attached Thumbnails Leaking Power Steering Pump-ps-seal-kit.jpg   Leaking Power Steering Pump-dealer-ps-pump.jpg
Old Nov 22, 2009 | 09:32 AM
that is it ,, but i would chk if dealer has it,, it costs about the same price or a few $ more but at least you install factory seals .......
you might want to get some p/s fluid and the nut to remove the frt pulley i believe that it has left handed threads ........also there are 2 rotors that go in the shafts , they have a dot in it , make sure to re install them same way that you took them off and install the proper rotor into the proper shaft ..longer shaft goes where the frt seal is
the picture that you posted above shows how they go,, just print it and have it with you when doing the job,,,
also the valve # 4 on above picture make sure to re install it same way that it came out , if you put it upside down you will have issues ,,
Old Nov 22, 2009 | 05:45 PM
Randy367's Avatar
Well sounds like pretty straight forward stuff, will do it this coming weekend. Will let ya all know how it goes. Thanks to everyone who helped out really appreciate it.
Thanks All
Old Nov 26, 2009 | 04:59 PM
Randy367's Avatar
Well worked on the car today, changed all the seals and o-rings in pump. It cured the leak at the seam and no more foaming of the fluid, so I guess that's where the air was getting into the system. It wasn't as hard as I thought it would be to pull off the PS pump. I was just afraid of making a big mess with the fluid when I disconnected the lines, but there was hardly any fluid coming out of the lines, just had to figure out how to pull the nut off the pulley, finally just pulled out the old impact gun and it came right off, and it was reverse threads on it. So appreciate all the help guy's. Saved me a couple hundred bucks. I love this site.
Thanks All
Accordian04
Sep 26, 2016 07:47 AM
95_Honda_Accord_Ex_Sedan
Feb 17, 2013 08:28 PM
jre3425
Mar 24, 2011 07:20 AM
lonberge
Oct 1, 2010 07:59 AM
skytech76
Jul 12, 2007 06:45 PM
