Odd engine knock
Old Jun 20, 2010 | 11:04 PM
kris_loehr's Avatar
h2oskibum:
I sent you a PM with a website that has a chart of the bearings which are by color
Old Jun 21, 2010 | 01:06 AM
if crank is ok,,,,,,install all green bearing get them from an part store that sells parts for import cars.....green is the middle of the colors .. i have done it like this many, many ,many times with no problems ,,you can always get some plastic gauge if you want , if you do so , make sure to properly clean all the plastic gauge before final assembly and torque the bearings properly ( 34 ft lb , do it in 2 separate stages),,also make sure to put some grease on the bearings on final assembly before torquing them
if you want to use factory bearings for the rods,,,,,,,,you read the letter or bar ( 1 bar =a 2 bars =b etc etc ) from the crank at each journal and the number or bar from the connecting rod......then you match letter and #( bar) and you get the colors
since Kris sent you a chart i won't post the colors here
I would also remove the oil pick up screen and clean it real good
yell if you need help
Old Jun 21, 2010 | 05:36 AM
h2oskibum's Avatar
Originally Posted by troycifer
my car has a knocking noise but it only happens when im on the gas pretty hard and let go right away. it only knocks once. is this the same thing or is yours a continuos knocking?
The one I'm working on the knock is...or was continuous, sounds like you might have something else going on. Maybe something is loose and when you load and then unload the drivetrain you are getting a clunk or possibly ignition related??? Someone else on here might be more help than I am, I haven't owned a Honda since I sold my 86 Prelude in 89.
Regards, Mike
Old Jun 21, 2010 | 05:47 AM
h2oskibum's Avatar
Well many thanks for all the advice to those that offered, but the rod journal is .023 out of round that wont cut it. So it looks like I will be pulling the motor out of the donor car after all. I may put this one on the back burner for now and put a crank kit in it later for a back up motor, with only 150,000 miles on it...it should have a lot of life left in it. The donor car has 260,000 miles on it and although it runs good and doesn't smoke I don't know how much longer it might last. What does a crank kit go for on one of these...ballpark of course
Regards, Mike
imjrk
Sep 25, 2017 12:29 PM
dave1977nj
Feb 28, 2011 10:41 AM
fusionstar
May 7, 2009 08:18 AM
rmistry7
Sep 28, 2006 05:05 PM
Jan 18, 2005 07:46 AM
