1997 Honda Accord
Old Jul 14, 2010 | 10:21 PM
gooch24's Avatar
Thanks for info. I was going to ask if anybody knew where the security system controller was located. I have checked all the fuses in the under dash fuse box and the under hood fuse box. I cant find any fuses that are blown. I will check to see if I can find the controller. Would the integrated control unit or the interlock system shut the starter, security and door locks off? Still looking for ideas.
Old Jul 25, 2010 | 09:52 PM
gooch24's Avatar
OK, new question. What is the gray plastic box that is located under the front passenger seat? It is mounted on the floor. The only thing I can make out on the box is ABS. It has a circuit board in it that difinetly has water damage. I am wanting to make sure what it is so I can find another one. I never did find anything under my dash with an antena on it. Still trying to figure this mess out.
Old Jul 25, 2010 | 11:20 PM
gooch24's Avatar
Nevermind. I just found out it is the door lock security control unit. Gee, that sounds like it might be the problem!!!!
Old Jul 28, 2010 | 10:15 PM
gooch24's Avatar
Ok people here was the problem. On a 97 Honda Accord SE, there is a door lock security control unit under the front passenger seat. If your door locks and security system both go out, I would check this module. From what I could gather, this module would only fit 97 Accord SE's. So it was a little hard finding one at a salvage yard. So to sum this whole deal up......if you drive into some water and it gets the inside floor board/ carpet wet, check the ECM and the door lock/ security control module. They are both located on or at the front passenger floor board. Peace out and Praise Jesus that I figured this mess out!!!
beagle76
Oct 9, 2011 12:37 PM
daniel216
Oct 9, 2007 03:05 PM
QGunner2
Sep 18, 2007 06:38 PM
97LX
Jun 11, 2007 09:03 PM
tampabayshore
Nov 7, 2006 11:15 PM
