No instrument cluster light ?
Old Aug 26, 2010 | 06:40 PM
piggylover1985's Avatar
Originally Posted by trevor_o
no they went at different times. so i dont think they are a connected problem. what is a multiplex n would it be on a 98?
yeah same every thing else lights up but the cluster.
Does climate control and radio light up too ? Did you check for the reverse lights ? As the instrument lights and rev lights share the same circuit i think.
Old Aug 26, 2010 | 07:16 PM
I also found this, you might want too check this out 2000 Honda Accord dash lights
Old Aug 27, 2010 | 05:05 PM
Okie, think i found the problem, tested prove that the driver side mutiplex unit is malfunction. When you turn on the combination switch on, the mutiplex should give the circuit a ground to turn on the back LED lights and all illumination lights, but it didn't. So i made a ground wire to ground the circuit, and everything lights up normal. I don't know if it hurt anything by doing this, but i'll take my chance temporary until i could find another good used one to replace it with.
Thanx guys.
Old Sep 5, 2010 | 11:15 AM
jrock25's Avatar
Default ?????
Did you ever find out your instrument panel lights problem
Old Sep 6, 2010 | 09:40 AM
Bad driver side mutiplex control unit.
Nebbb_98
Sep 4, 2008 05:11 PM
CougarMark67XR7
Dec 24, 2007 01:08 AM
Bernman
Mar 18, 2007 03:52 PM
imnoweirdo
Jan 29, 2007 05:49 PM
marbro
May 20, 2006 10:13 PM
