03 Accord with 2 12s
Old Sep 13, 2005 | 02:31 PM
PilotForLife86
Default 03 Accord with 2 12s
Hey everyone, I just installed two 12" subs into my car and my trunk rattles like hell...what should I do about it? Dynamat? or is there something cheaper that actually works....
thanks
Old Sep 13, 2005 | 07:12 PM
Default RE: 03 Accord with 2 12s
You Got The Answer yourself ....DYNAMAT...
Welcome to the forums...
ORIGINAL: PilotForLife86
thanks
Old Sep 13, 2005 | 09:22 PM
PilotForLife86
but, it only rattles behind the license plate...if I press down on the trunk it will stop, if I push on the license plate it will stop a little bit but it sounds like rattling is between the fabric and the metal(inside the trunk lid), so if I put dyna mat on that section it will weigh it down a bit and keep the sound towards the front of the car right?
Old Sep 15, 2005 | 12:31 AM
theycallmerickjames's Avatar
i've got an 05 accord and i had the same problem. you need to take out the WHOLE licence plate assembly and put dynamat in between the assembly and the trunk.... and some behind the license plate
Old Sep 15, 2005 | 07:47 PM
PilotForLife86
how is that possible...I know you take out those plastic screws in the fabric on the trunk lid...then what?
Old Sep 18, 2005 | 07:44 PM
there are two bolts... loosen and remove the nuts to them in your trunk lid...... it's a biatch to get this off, so be carefull
Old Sep 18, 2005 | 11:13 PM
PilotForLife86
but isn't the holder welded to the trunk
Old Sep 26, 2005 | 11:16 AM
accorddriverc's Avatar
my plate rattles too. I need to fix that
Old Sep 28, 2005 | 01:29 AM
umm, no the "holder" is not welded to the trunk... like i said.... BOLTED
Old Oct 10, 2005 | 02:56 PM
remington870_20ga's Avatar
Dynamat is good. You can also look for a little less thick generic stuff at your local hardware store.
