Maintenance Req'd light - make it go away, please!
Old Dec 3, 2004 | 10:07 PM
GolfingTiger
Default Maintenance Req'd light - make it go away, please!
Here's the car:
1998 Honda Accord EX with the V-6 engine.
How do I get the Maintenance Required light on the instrument panel to turn off? I'm a stickler for regular maintenance and I hate that red light glaring at me when I'm babying the car to death. Thanks!
Old Dec 6, 2004 | 09:39 PM
Default RE: Maintenance Req'd light - make it go away, please!
Since the '04 I have now is my first Honda I don't have the knowledge to answer you. If you have the owner's manual I'll bet it's in there. If not your local dealer would be the way to go. A phone call will do the trick.
Old Dec 7, 2004 | 03:11 PM
poff1986's Avatar
1- turn the key to off
2- push in your trip odometer button and hold
3-turn the key to on
4- wait about 10 seconds and it will shut off completely
5- GOOD TO GO!
Old Dec 7, 2004 | 11:55 PM
Did Poffs suggestion work for your red light on problem.
If it did let us all know so we can do the same thing, I haven't had the light ever yet but if I get it Id like to know if that worked..
Old Dec 8, 2004 | 09:57 AM
It does work on the 03/04 Accords, I've reset mine that way. I just wasn't sure if the older models used the same procedure.
Old Dec 8, 2004 | 08:28 PM
GolfingTiger
Yes, it worked. However, I have to do it each time after the car has been stopped and restarted. The light returns each time, but will go away by following the procedure listed above until you shut the engine off. On my '98, it will return once you restart the engine.
Remember, this is the "maintenance required" light, not the check engine light. Two very different things. My light is Honda saying "come in for your $600 oil change and new air filter" one!
Old Dec 9, 2004 | 03:13 PM
GolfingTiger
UPDATE!
After filling up with gas this morning, I did the procedure again as set out above. Now the light has stop coming back on after stopping then restarting the engine. Don't ask me why, but it is working now.
Glad to be rid of that sucker glaring at me! Thanks to everyone for the assistance and help.
Old Dec 11, 2004 | 09:46 AM
poff1986's Avatar
HMM! SOUNDS TO ME LIKE A CHECK ENGINE LIGHT...CEPT FOR YOUR GAS-CAP..DID U NOT HAVE IT TIGHTEND????
Old Jan 15, 2005 | 06:02 PM
bonylad
Your MRL (depending on year and engine) will come on every 7500 miles for older 4 cylinder and all 6 cylinder cars. New 03 and up 4 cylinders are on 10K intervals.
The directions posted are accurate; however, make sure you headlights are not on. It will not reset if you wait for the lights to turn off themselves. You know to what I refer. Make sure they switch is OFF.
Old Jan 17, 2005 | 02:07 PM
Hi again bonylad...
I checked with my Honda Garu and he confirmed as all of you have been saying is that you are all right...
Only thing he said was this....[sm=badbadbad.gif] ....Dammm you all...no longer will we be able to do the $600.00 check engine maint thingy....
Later Good Members[sm=icon_cheers.gif]
