NEED HELP!! my new tires are rubbing...
Old Oct 11, 2005 | 03:05 AM
bullet099
Default NEED HELP!! my new tires are rubbing...
I recently upgraded my stock 205/60 - 16 x 6.5 to 225/45 - 18 x 8. Now when i hit a bump or make a sharp turn the tires rub, im guessing on the fender. What should i do abotu this problem?
Old Oct 11, 2005 | 01:17 PM
dinzer's Avatar
Default RE: NEED HELP!! my new tires are rubbing...
welcome,
well as i see it, you have only one option get some coilovers and raise your car.
what suspension do you have stock??
Old Oct 11, 2005 | 05:50 PM
6thgen's Avatar
8" wide is pushing it in an Accord, but can be done without rubbing. What's the offset?
Old Oct 12, 2005 | 01:39 AM
bullet099
Thanks for your help guys. The offset on the new rims is +42mm. From a side view of the rims it looks as it they will fit up into the fender. The only thing holding them back is the small metal lip on the inside of the fender. A friend told me that this could be rolled back?? Would getting stiffer springs be another solution??
vandium
May 1, 2010 09:46 PM
maro
Mar 10, 2007 12:15 AM
FlyLow
May 8, 2006 06:00 AM
hnic514
Apr 9, 2006 05:24 PM
Gummi_67
May 26, 2005 10:53 PM
