Amp problem
Old Oct 18, 2005 | 10:09 AM
accorddriverc's Avatar
Default Amp problem
I am having an issue with the amp for my subs. The power seems to be intermittent. I thought that the wire didn't have a good connection to the connector so I seperated it and reconnected it but I still have the problem. I noticed a spark(scared the hell outta me) when I screwed the connector to the amp. I also noticed that if I press down on the connector when the power is acting up, the amp will come back on. Could it be that the connector that is holding my power wire is bad?
Old Oct 18, 2005 | 10:17 AM
6thgen's Avatar
Default RE: Amp problem
Is it the correct gauge? Are the connectors clean?
Old Oct 19, 2005 | 09:24 AM
ORIGINAL: 6thgen
Yes, it is 4 gauge. I took it apart and looked at the connectors, and they seem to be clean. I flipped the connector holdin the poewr wire and it seemed to screw in more securely. It hasn't happened again since I did that so I'll see what happens.
drumdoctor
Jan 16, 2012 09:53 AM
CarlisleP&SPaddy
South
Jan 22, 2010 10:39 AM
zachyzissou
Feb 15, 2009 11:12 PM
Nadoo
Jan 7, 2008 12:19 AM
