'97 Timing belt replacement
Old Dec 10, 2004 | 11:34 AM
21tgs
Default '97 Timing belt replacement
I am replacing the timing belt on a ’97 with the F22B2. Everything is going just fine except that I can not break the crankshaft pulley-retaining bolt free. I’ve used my impact gun and a 24” breaker bar. Has anyone run into a similar issue? If so how did you finally remove the bolt?
According to the manual Honda uses a special tool to hold the crankshaft pulley via the 50mm hex in it. Last night I didn’t have one. This afternoon over lunch I will make one in the tool room here at work. May be this will help.
Old Jan 29, 2005 | 06:36 AM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Sep 6, 2005 | 04:13 PM
Oldrndrt
Default RE: '97 Timing belt replacement
I am having the same problem on my daughters 98 2.3L Vtec. Can anyone tell me where to get one of the tools or have one I could beg borrow or buy (cheap...yeah I know [:'(] don't say it...) I would appreciate any help you could give.
Old Oct 25, 2005 | 10:08 PM
Evlampius's Avatar
have you tried Crank Pulley Bolt removal tool? [&:]
Old Nov 11, 2005 | 02:47 AM
7thGen's Avatar
I just use a 1000 ft-lb impact gun to remove it. Have done two Civics three 3g Preludes. Some people on other sites will have a shop break it loose then go home and finish the job then take it back to have it tightened with the impact.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
