Engine shuts off when stock airbox removed?
Old Aug 16, 2007 | 10:36 AM
SandMan's Avatar
Default Engine shuts off when stock airbox removed?
I noticed that my car will not run (ie the engine shuts itself off) when you remove the stock airbox which houses the sensor and the stock air filter unit. So I'm wondering how I am going to install a CAI - since the car will not run without the stock unit attached. Is there some way that a CAI would relocate the air sensor unit and prevent the engine from shutting down? Or is the 07 Accord too smart now for aftermaket parts??
Old Aug 16, 2007 | 11:19 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Engine shuts off when stock airbox removed?
Do you mean you took out the whole stock airbox assembly from the throttle body forward? I would not want to run my engine with no filter at all -you could suck all kinds of crap into the trottle body. On the 2000 there is a small breather tube that has to be hooked up to the SRI or CAI. Could that be the problem? Can you post a picture?
Old Aug 16, 2007 | 02:25 PM
SandMan's Avatar
I didn't remove the whole airbox, and run the engine like that. I had a feeling that the engine wouldn't run with an aftermarket intake, b/c the mass airflow sensor is attached to the top of it. So I simply disconnected the clamp around the intake tube , and let it breath open air for a moment with the car sitting, and the engine then shut off on its own. So unless a SRI or CAI includes a way to reattach the MAF sensor unit, I know that it's just not gonna work.
Old Aug 16, 2007 | 02:26 PM
SandMan's Avatar
sorry if that was confusing, i meant the MAF sensor that sits on top of the stock airbox. When that gets bypassed, the engine quits. So does an aftermarket unit have a way to reattach this sensor?
Old Aug 16, 2007 | 04:56 PM
03Sleeper's Avatar
Umm....what year is your accord? if you have a 7th gen (04+), most manufacturers have already converted their air intake tube designs. There's actually a lil slot on top of the intake tube where your MAF sits and regulates.
Old Aug 16, 2007 | 05:15 PM
Velocifero's Avatar
ORIGINAL: 03Sleeper
03+ you meant, right bud
Old Aug 17, 2007 | 10:16 PM
SandMan's Avatar
what did you mean by "converted their air intake tube designs"?
the sensor sits in a little cut out, it's screwed in. I have an 07 Coupe.
Do you all know of any CAI or SRI that would fit my car? I can't find anything for my year on the web.
Old Aug 17, 2007 | 10:18 PM
dan_o_89_rs's Avatar
that sensor a maf? sounds like a iat sensor to me... but maybe not. i just thought all or most mafs were in the tube section positioned in the center of the tube... good luck
Old Aug 17, 2007 | 10:21 PM
can u post pics? i dont think many ppl are familiar with the ins and outs of the 07.
Old Aug 20, 2007 | 03:34 PM
Registered User
I thought the 07's were the same as the 06's but I could be wrong. I would think an intake for an 06 would fit your 07, but I am not positive. Go look at some pics of 06 models and 07 models on eBay. Most auctions have pics. If your engine looks identical to an 06's engine, then an intake for an 06 would work.
o440
Aug 11, 2008 11:07 PM
o440
Jun 29, 2008 08:14 AM
mike_tran
Aug 22, 2007 05:17 PM
Sparco_racingVTEC
Dec 21, 2006 02:37 AM
2000LXV6
Nov 19, 2005 12:45 AM
