86 accord starter problem
Old Aug 29, 2007 | 09:50 AM
gpsodave
Default 86 accord starter problem
86 accord with 32k orig miles on it. When starting the car, the starter just whirrs, does not kick into flywheel and turn engine. I have already:
replaced the starter twice (both did the same thing)
has a new battery and coil
when disconnecting the switch wire and jumping the starter posts, it just whirrs
the batt cables have never been replaced, but are not corroded and it looks to be ok on the ground, etc. The car sat or was used for 3-5k per year, but have been using it on a daily basis for about 8 months with no problems. Replaced most of the hoses, belts, alt and AC since putting back on the road.
Hate to tow it to local Honda dealer, who doesn't have a very good service reputation out here.
Thanks in advance for any thoughts.
Old Aug 29, 2007 | 12:39 PM
Default RE: 86 accord starter problem
ORIGINAL: gpsodave
when you say you replaced it 2 times,,, does it whirr immediately soon after you replaced it ,, or after a while..
have you used non-honda stsrters ?? you also might want to chk the teeth on the ( flywheel -torque convertor) if they are worn , it could also make starter not to engage
if teeth are ok and you have used non-honda starter i would try a Honda starter
Old Aug 29, 2007 | 12:45 PM
gpsodave
After the first replacement, (6 weeks, 500 miles) it started to whirr. After putting in the new one, it whirred immediately. These were both AutoZone reman Matsubi starters, which looked just like the original. So go with new Honda OEM instead of reman?
There was no sign of wear on starter teeth, have not peeked into the flywheel. Thanks for the help.
Old Aug 29, 2007 | 01:54 PM
if the teeth on the flywheel are ok, and all the wiring is ok, I would go with a Honda part , it is a bit more expensive but it will last a loooot longer ,,
you might want to get one online , could save some money , unless you are pressed for time and need it done ASAP.
Old Aug 29, 2007 | 02:34 PM
gpsodave
talked to the Honda dealer, all they offer is American Hinda remans. The parts guy said to check the ignitor, the flywheel extension- whatever that is) and the timing belt as well. I need to double check and see if the engine is actually turning (meaning my whirr is actually spinning the motor).
Saddlebum
Dec 14, 2012 05:15 PM
Donda
Aug 20, 2010 12:40 AM
R1ckyB0bbyyy
Sep 8, 2008 01:48 AM
remnam
Jun 6, 2008 10:22 AM
fmeier
Jul 22, 2006 02:14 PM
