97 accord heater valve replacement
Old Dec 20, 2004 | 03:22 PM
capww8
Default 97 accord heater valve replacement
97 honda accord
I was just wondering if anyone could help me locate the heater valve. I know what it looks like, but I have no idea where it's situated inside the engine bay.
Also, I may be wrong about what the problem is. Basically, there is never any hot air blowing out the vents. I believe the control **** works, because the heater was weakening as it was getting colder, and we had always maintained some control over the temperature of the blower. In my experience, this usually indicates a faulty HCV.
Anyway, any help would be greatly appreciated.
thank you.
Old Jul 18, 2008 | 09:10 AM
Default RE: 97 accord heater valve replacement
Its in the engine bay near the firewall. Towards the right-side of the car about mid-elevation.
Do you have a 4-cylinder or a V-6??
Do you have auto climate control??
Old Jul 18, 2008 | 05:29 PM
hondadude's Avatar
ORIGINAL: kurtdaniel
On most hondas, heater valves are in the heater core. This illustration may help you - http://autorepair.about.com/library/...bl303a-lib.htm
As shown in the link, the heater valve IS NOT located inside the heater core. It is located against the fire wall in the engine compartment on the passenger side.
Old Jul 18, 2008 | 07:25 PM
This problem can also be caused by simple cracked heater control ****, not actuating the stem the **** fits over. Pull **** off and check.
Also, the push/pull wire that actuates the heater core valvecan become disconnected under pax side dash.
You can manually actuate the heater core valve on the engine side of firewall to see if it move easily. If yes, then one of above should fix your problem.
tashier
Aug 24, 2015 01:43 PM
HK500Pilot
Apr 24, 2013 07:31 PM
weannaun
Jan 3, 2013 10:50 PM
NZXTInerTia
Jul 20, 2012 03:06 AM
Eggbert
Mar 27, 2012 05:43 PM
