Ground wire
Old Oct 24, 2007 | 10:24 PM
magiconthetire's Avatar
Default Ground wire
For you guys with the 03-07 accord, where did you ground the ground wire when installing an amp. In my old civic, i just had it bolted in with the tail light for 1.5 years and not one problem, but i want to place it somewhere thats hard to see. Any input would be helpful. Thanks
Old Oct 25, 2007 | 01:36 PM
Default RE: Ground wire
Where did you mount your amp?
Old Oct 25, 2007 | 03:15 PM
MacLeod's Avatar
I drilled 2 holes in the sheet metal in the pass thru, sanded off all the paint and stuck them there. But I mounted my amps close to the front of the trunk. You want to keep your ground wire as short as possible.
Old Oct 25, 2007 | 10:17 PM
Briggz's Avatar
Almost A Senior Member
Mine's bolted down with the trunk latch. The plastic comes up, and you can run the wire underneath, totally unseen.
Old Oct 25, 2007 | 10:54 PM
Thumper26's Avatar
perfect timing. I'm going to have to address this soon.
can you go straight through the floor by the back seats, or is the gas tank too close? Also, will self tapping screws pass in the lanes, or do I need to do the bolt thing?
Old Oct 26, 2007 | 01:40 PM
ORIGINAL: sir_nasty
the amp is just sitting in the trunk infront of the enclosure.
ORIGINAL: Briggz
thats perfect, great idea! thanks for the help everybody
Old Oct 26, 2007 | 04:58 PM
MacLeod's Avatar
ORIGINAL: Thumper26
Ya gotta use the bolts.
Go to MECA's website and get the PDF file of their install rules. Itll give you a really good idea of what is expected.
http://www.mecacaraudio.com/sqlrules.aspx
Old Oct 29, 2007 | 12:21 PM
HuYnHness's Avatar
there is a spot that something else is grounded on that i used but i have a feeling its actually not a very strong grounding spot. its like on a hump right behind the rear seat.
doat
Aug 2, 2009 09:11 PM
Contriver
Dec 31, 2007 12:18 PM
03Sleeper
May 2, 2007 08:01 PM
Green_Accord
Apr 5, 2006 04:11 AM
F23AccordLX
Feb 24, 2006 07:48 AM
