View Poll Results: A poll
Tsudo Catback Exhaust System
25.00%
Body Kit
0%
Racing Seats
0%
Coilovers
50.00%
Paint and Body
0%
Wheels and Tires
25.00%
Exterior Misc(Tailights, neons, headlights...)
0%
Voters: 4. You may not vote on this poll
What should my first mod be?
Old Dec 7, 2005 | 01:48 AM
zelseman's Avatar
Default What should my first mod be?
Im about to turn 16, i have a 91 accord lx, and im doing an h22a swap next winter, so what mods should i add first?
Old Dec 7, 2005 | 10:38 AM
6thgen's Avatar
Default RE: What should my first mod be?
Lower it.
Old Dec 7, 2005 | 08:34 PM
dinzer's Avatar
start with suspension, coilovers, then anti sway kit.
then wheels, tires and most important stoppers, brakes, get your base built, then add power
Old Dec 8, 2005 | 02:48 AM
The quickest mod that one can do and see the results is of course the Tires and Wheels...most pleasing to you and to others who will look at your ride...
Of course that's only my opinion....
WheelBrokerAng [sm=signs003.gif]
Old Dec 8, 2005 | 04:31 AM
zelseman's Avatar
Im new to the whole Auto Modification Scene, so how are the quality of these wheels, and what is my bolt pattern? http://store.summitracing.com/defaul...0&autoview=sku
Old Dec 8, 2005 | 01:27 PM
6thgen's Avatar
If it's a 4-lug 4x114.3 (4.5) or 5x114.3 for 5 lugs.
Old Jan 9, 2006 | 02:31 AM
latoilette's Avatar
WHEELS
Old Jan 9, 2006 | 04:22 AM
you have a 4 bolt pattern 4x 4.5. someone has already said it and i have to second it, build the base. if your going to drop a h22a in there you are probably going to be going over 110 regularly. **** i do that with my f22. suspension and brakes. you dont have to go expensive to get good handling and ride. comptech springs over koni orange shocks, tien springs over tokico shocks or kyb illumina's eibach whatever. Brakes are the first thing i would do because you need a couple of things, first swap out those drums out back cause they suck. hit your local boneyard and get the rear end off an SE, they should hook it up for about 200 bucks, then you need drilled rotors and good pads all the way around. at a dollar thirty your stock brakes will gas out so fast.
lightshow
Tsuki TsuKi
Apr 14, 2012 10:50 PM
superfly831
Feb 8, 2012 12:27 PM
I-reef
Nov 11, 2010 07:59 PM
BigRigg
Jan 25, 2009 03:24 PM
Crankshaft
Nov 10, 2006 04:44 PM
