looking for IAT sensor??
Old Jan 2, 2005 | 10:59 PM
Guest
Default looking for IAT sensor??
does anyone know where the IAT sensor is located on a 94 F22B1 motor???
also here are a few pix of my new car
www.msnusers.com/94accord
Old Jan 3, 2005 | 01:55 AM
Guest
Default RE: looking for IAT sensor??
anyone????
Old Jan 4, 2005 | 04:47 AM
Why Yes I do as a matter of fact..
The IAT sensor (Intake Air Temperature) sensor is located on the side of your intake plenum.
You can test this part to see if it's any good by useing a ohmmeter. With the engine turned OFF and the ignition switch turned ON , disconnect the electrical connector from the IAT sensor which as I said before is located on the side of the intake manifold. The resistance between the two terminals should be between 1K and 4K ohms, If the test is not in line with this number than I recommend you replace the IAT sensor.
Hope this helped and that I didn't carry on to long...[sm=smiley23.gif]
Old Jan 4, 2005 | 01:58 PM
Guest
can u tell me which one it is excatly?? there are 3 or 4 sensors on the intake mani..
Old Jan 9, 2005 | 04:41 AM
Let;s see here, there is only one IAT located on the side of the Intake Plenium and if you dont know what it looks like, then I suggest that you go down to your local AutoZone or Advance parts store and have them show you one.
Then you will know what it looks like, if your standing looking at your engine then it;s on the drivers side of the plenium area...
Hope this helps you out[8D]
Later...
chrw
Mar 10, 2011 06:46 AM
vancent60610
May 19, 2010 07:41 PM
haoleflip
Aug 4, 2009 06:14 PM
greatday57
Aug 10, 2007 06:20 AM
01_accord_89
Jul 4, 2007 09:40 PM
