tire size question
Old Dec 14, 2005 | 12:41 AM
larsonk
Default tire size question
I have some tires and rims that i am going to sell to a friend for a 2005 Honda Accord LX. My question is that the tire size is 205/40/16. Is there any problem with putting these tires on that car? They fit, but i wanted to double check before selling them to her. Thank You for any input.
Kurt
Old Dec 14, 2005 | 04:56 AM
dj.fli4rt
Default RE: tire size question
Depends on which model your friend has. Here's some quick stats i found for you:
Accord 2005 [how the change will effect the car:]
Coupe/Sedan v4: oem - 205/65/15. Speedometer reads: 60mph. Actual speed: 52.9.
Coupe/Sedan v6: oem - 205/60/16. Speedometer reads: 60mph. Actual speed: 52.5.
The rims won't cause any problems since they fit, but your friend will have difficulty determining how fast the car really is going since the difference of size of the tires will effect what the speedometer reads.
Here's a tire calculator if you or your friend want to find the right tires equivalent to the oem.
www.miata.net/garage/tirecalc.html
edit note: spelling correction.
Old Dec 14, 2005 | 07:13 AM
larsonk
Thank you for the info DJ. I assume safety should not be an issue other than the quality of tire being used?
Old Dec 15, 2005 | 03:20 AM
The tire and rim package will fit the vehicle with no know problems..
WheelbrokerAng[sm=americanasmiley.gif]
Old Dec 15, 2005 | 04:52 AM
larsonk
thanks for your input wheelbroker. There will be the issue with the speedometer not being accurate right? Do you know of any products and or ways in which it can be fixed? Thanks
kurt
06AccordVp
Apr 28, 2010 01:25 PM
drive2getthere
Feb 13, 2009 05:36 AM
kahnvict850
May 4, 2008 08:47 PM
jamoke59
Sep 15, 2007 06:02 PM
izncate
Jun 11, 2007 04:59 PM
