[Deleted]
Old Jan 15, 2005 | 08:03 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Jan 15, 2005 | 08:06 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Feb 19, 2005 | 09:37 AM
Default RE: Exhaust upgraded then ... my car slower
It's possible that it is simply too large in size. All engines need some backpressure to make max horsepower.
Old Mar 16, 2005 | 06:10 PM
1993accordSE's Avatar
what u also need to do is get a complete kit instead of just a muffler or an axel back just go with the cat back u wont regret it. Payce
Old Mar 16, 2005 | 09:34 PM
2000Ex's Avatar
Backpressure is a myth but if it is not the right size you can hinder performance.
Old Mar 23, 2005 | 10:01 AM
ORIGINAL: 2000Ex
I disagree. I have witnessed dyno runs with and without open exhaust. In one case the engine made more HP WITH some restriction/backpressure.
Not true in all cases I admit, but to call it a myth is not correct.
Old Mar 23, 2005 | 01:48 PM
Patrick's Avatar
smaller CC engines requrie a certain amount of back pressure...even V8s require some back pressure...you dont want to have a higher volume of exhaust flow than you do exhaust valve size. for instance, on a V8 i built...it has 1.67inch exhaust valves, the guy bought 1 7/8 inch headers, which were too big...he found that he had more low end torque with a 1 5/8 inch headers...you dont actually lose power, you lose initial torque..the reason people say that "smaller engines are more affected, is because they have less low end torque. take 2 cars, for example...a 2002 Accord V6, and a 2002 Camaro SS. you can hinder low end torque on both vehicles by putting too big of an exhaust system on them, but the camaro has around 300ft/lb of torque, whereas the accord only has around 175 (i think) so when a oversized exhaust may cause, say, a 10% low end torque loss, it is alot more determental on the accord with the smaller engine.
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 26, 2005 01:41 AM
