Random Fuel shut off......
Old Feb 18, 2008 | 07:32 PM
simplified
Default Random Fuel shut off......
HI, I have a 92 Honda Accord and the car starts up fine and runs for only about 45 secto 1 min. has spark and i thought it might be a pluged up fuel line. i changed the fuel filter and i also took the fuel line off of the injector bar and placed it in a bucket. i turned the key to on and it sprayed a good short burst of gas as i would think to prime the motor and then i tried turning the motor over and it sparyed again fine so i knew nothin was blocked but if i hook it back up it will still only run for about a min. so i also changed the fuel pump relay and it still did the same thing. i dont think its the pump because it sparys strong and just cuts of randomly for some reason. any help would be greatly appreciated thank you.
Old Feb 19, 2008 | 11:14 AM
98accordlx's Avatar
Default RE: Random Fuel shut off......
once the pump in my prelude worked sometimes and didnt work others, but that was generally when i was starting the car, never had it cut out while it was running.....
maybe the feul regulator?
tomd
Mar 9, 2013 06:35 PM
billiamhonda
Dec 9, 2007 11:39 PM
accordinglyslow
May 8, 2007 10:24 PM
jshrade
Dec 11, 2006 01:38 AM
pixelmonkey
Sep 3, 2006 04:18 AM
