How much lowering can we do and not get camber kit
Old Jan 6, 2006 | 04:28 PM
latoilette's Avatar
Default How much lowering can we do and not get camber kit
That's my big question.
I have 1996 honda accord lx v6, with stock springs and dropzone springs.
I have camber kit in the front, but I have negative camber in the rear.
how much lowering can I do and not get camber kit?
Old Jan 6, 2006 | 10:18 PM
Default RE: How much lowering can we do and not get camber kit
you can slam that bitch to the ground. its not going to hurt anything but your tires. any lowering is going to need a kit if you want even tire wear though
lightshow
Old Jan 11, 2006 | 08:46 PM
George Knighton's Avatar
ORIGINAL: latoilette
The OEM Honda HFP Suspension for the 2003-2005 cars will lower the CM8 an inch, giving 2 degrees of negative camber in the rear, and no adjustment is required, per factory instructions.
You can go up to around 3.5 degrees of negative camber front or rear without causing tyre wear so long as total overall thrust is correct and the toe in is corrected after the installation of the suspension.
Old Jan 13, 2006 | 03:26 AM
um im not trying to be argumentative or anything, but have you ever rolled around with 3 DEGREES of negative camber?! holy **** your tires are going to be toast after 10k miles. now i actually have 1.8 degrees front and back negative with all other measurments withing spec, and the insides of my tires are always the first to go, i get about 20k to a set.
lightshow
Old Jan 13, 2006 | 11:02 AM
The answer to your question is yes, I have and do. My DC2 ITR track car has about that much negative camber on the front, and it's a car that I still drive to the track. There is no unusual wear pattern. The street tyre are Hankook Z212, and the track tyres are Toyo RA1.
Most of what people interpret as "camber wear" is actually wear caused by uncompensated toe in changes inherent in the lowering of an old double wishbone car.
ORIGINAL: lightshow
Old Jan 13, 2006 | 11:04 AM
I just double checked, and the Honda factory specifications for the HFP suspension on a 2003-2005 Accord call for no adjustment to the 2 degrees of negative camber caused by the one-inch drop of the factory HFP suspension for that car.
roozoo
May 24, 2012 02:46 PM
sg1320
Sep 4, 2009 10:46 AM
thunder_x
May 7, 2006 12:57 PM
roozoo
Feb 12, 2006 10:37 PM
19accord95
Feb 11, 2006 02:06 AM
