sway bar size
Old Jan 23, 2006 | 09:14 PM
boots's Avatar
Default sway bar size
Yeah Im going to order a larger rear sway bar for my 94 accord EX, I want to know the stock sway bar size. Thanks
Old Jan 24, 2006 | 07:03 PM
Default RE: sway bar size
i dont know the exact size of the bar, it is probably less than an inch, if you want to know the size, just take out your trustly dial caliper or you micrometer, (you should have both of these in your tool box), they will be able to tell you the size down to the hundredth of thousandth.
lightshow
if you looking at the suspension techniques bars, they are significantly thicker than the stock ones, you will notice it.
lightshow
Old Jan 24, 2006 | 07:13 PM
boots's Avatar
ok thanks, Im looking at them on ebay, $130 for a Progress Technology Rear Anti-Sway Bar ( RSB ) 22mm, I was just wondering how much bigger it is than my stock one, my stock one is so small, or what you said for $180. I will probably go with the progress one.
Old Jan 28, 2006 | 07:39 AM
well one inch is 25.4 mm. but it also depends on what material is used. different metals make for different stiffness. progress group is a world class suspension producer, they helped with the suspension on the worlds first 200 mph civic.
lightshow
Old Jan 30, 2006 | 10:48 AM
boots's Avatar
Ok thanks for the info, Im going to go with the progress sway bar, I like it the best, Thanks
Old Jan 30, 2006 | 07:19 PM
boots's Avatar
Also, I heard someone talking about if you go to big on a sway bar it can bend your subframe, I won't be doing any big turning, but I eas just wondering if this was true or not. The sway abr Im going to get will be 22mm. Thanks
rob3201
Jan 19, 2014 01:09 PM
FoShoHondo
Jul 8, 2008 05:43 PM
street_racer7112
Sep 16, 2007 06:51 PM
accords own
Aug 15, 2007 01:01 AM
sekander007
Sep 22, 2005 12:03 PM
