Help? I think?
Old Feb 11, 2005 | 10:06 PM
Jessica
Default Help? I think?
I recently bought a 1990 Honda Accord from a private seller for a thousand dollars. He stated the only problem with the car is that the CV boots [or whatever they are] needed to be replaced. The seller asked us not to drive the car since there weren't any license plates on the car at the time. I should have been questioning of him, but he seemed trustworthy so I ignored it for the most part. Once we got it home, we discovered many other problems with the Honda. My mothers boyfriend stated when he got up to about fifty-five, the car started shaking quite a bit. The gauges didn't work whatsoever, the car is a bit loud when it's running - especially when turning, the brakes go to the floor when you barely put any pressure on it at all and the gas pedal needs a little more than usual pressure applied to it. There are a few other problems, such as the drivers door not opening until you try about hundred times. It seems that someone had tried to break into the car previously and pretty much screwed up the entire door. The windows had been replaced sometime in the past because the windows are definitely not the right size - they don't fit under the seal. The drivers seat isn't even bolted into the car! I'm just wondering how much it might cost to get everything working alright. Any comments? questions?
Old Feb 12, 2005 | 03:05 AM
Default RE: Help? I think?
Jessica you I think have been had..
If you go to the police and tell them you were sold a unsafe vehicle and show them all you've put in here then you may stand a chance on getting your money back..
The police I'm talking about would be your State Police, they are the ones who inspect cars for road worthiness..
Check it out with them and see if I may be right.. By the way WELCOME To The Forums..
Old Feb 15, 2005 | 12:10 AM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Mar 14, 2005 | 03:58 PM
Jessic..did you do anything about your car...I'm sure we'd like to know what the police did for you..
RachelC87
Jun 17, 2013 12:52 PM
mamtsberg
Mar 17, 2010 09:15 PM
YeuEmMaiMai
Aug 3, 2006 03:02 AM
nygamble
Apr 25, 2006 04:54 AM
dj.fli4rt
Dec 27, 2005 10:07 PM
