Ball Joint Play
Old Feb 11, 2006 | 03:06 PM
shanmanz
Default Ball Joint Play
Hi
I am new to this forum. My dealer says that my accord has a play in ball joints and is asking for $478 to replace those. The car has 97800 miles on it. Is there a way I can verify that.
Is that a right amount to pay
Old Feb 12, 2006 | 10:38 PM
Default RE: Ball Joint Play
yea thats about what it costs. there is no need to replace them unless your having uneven tire wear. ie the insides of your tires are wearing out first.
Old Feb 12, 2006 | 11:46 PM
Lightshow has the right answer to your questions, how did the dealer arrive at his summation??? Did he even put it on the rack and test the ball joint play???
His price is Quite high!
Old Feb 13, 2006 | 05:56 AM
yea i would never pay 480 bucks to have it done...it only costs about 50 to do it yourself.
Old Feb 19, 2006 | 11:32 PM
ORIGINAL: lightshow
Man, I wish I had your mechanical knowledge....and tools! Things like that I just pay the piper, I'm good at many things but nothing that heavy duty. when it comes to steering, brakes, etc. I break out the Visa!
Old Feb 20, 2006 | 02:22 PM
well a machine shop can take out the old ones and put the new ones in if you just take off the knuckle.
Old Feb 20, 2006 | 02:23 PM
anyone that wants to do it i can give a full write up..
Old Feb 28, 2006 | 04:06 AM
calenatar's Avatar
got a write up for uppers on an 89 lx? i found a set with control arms with the ball joints already in them that i will probably get...or should i just get the joints themselves and not screw with the control arms?
Old Mar 1, 2006 | 02:25 AM
mmmm the uppers usually dont go out its the bottom ones. but they are really easy. pm me if you do decide to do it and you want the write up.
Old Mar 1, 2006 | 03:11 AM
calenatar's Avatar
yeah i am almost 100% sure its the uppers. when in the air i can push on the top of the wheel and it clunks back and forth cause its so loose. my mechanic friend says they are uppers. that are bad. and maybe tie rod ends
imdawrlus
Mar 15, 2012 09:08 PM
Shocker
Aug 15, 2007 12:39 PM
Hoang_Nguyen
May 13, 2007 10:13 AM
wietgr
Feb 11, 2007 07:27 AM
Hondaccord
Nov 4, 2006 06:30 PM
