Sport Transmission Indicator Light
Old Sep 2, 2004 | 03:22 PM
maha83
Default Sport Transmission Indicator Light
I have a 91 Honda Accord Ex 4dr and my sport transmission indicator light has come on without me having to push the button on the side of the gear shift. Is there any way I can dissconnect it from the transmission because I don't drive in the sport transmission anyway. It did the same thing a couple of years ago and I had to get another transmission because I drove around too long with it being like that. I just changed out the computer thinking that that was the problem, but it wasn't. IF anyone knows how to remedy this problem, please help!
Old Oct 18, 2004 | 03:53 AM
90JDMACCORD
Default RE: Sport Transmission Indicator Light
IF ITS BLINKING YOU HAVE A PROBLEM IF NOT PROBABLY JUST A LIGHT MALFUNCTION. ANY SLIPPING CLUNKING OR SHIFTING PROBLEMS? I HAVE A 90 LX THAT I PUT A F20A IN AND MY LIGHT HAS BEEN BLINKING EVER SENCE LAST DEC SLIGHT PROBLEMS WITH TRANY BUT IT HAS 187K MILES. MUST PULL TRANNY OUT TO CHANGE FILTER SUKS 2 B US
Old Nov 23, 2004 | 12:51 PM
poff1986's Avatar
i have no idea, will try to find more info about it..good luck in the meantime!
Old Jan 2, 2005 | 03:51 PM
Guest
Is it flashing or just lit? Use the jumper in the right side passenger under dash to trip the computer into diagnostic mode and count the flashes and compare to your Service manual. Must remove trim and pull back front passenger carpet
Do you want to sell your extra computer I need to replace mine with a known good computer to eliminate the possibility of a computer causing no shift problem
860-833-7004
charlieadams
Sep 18, 2012 07:11 PM
Ice D
Jun 30, 2011 08:48 PM
rpierce0524
Feb 25, 2005 11:42 AM
