What Fuel injector do you use?
Old Feb 24, 2005 | 06:47 PM
Guest
Default What Fuel injector do you use?
Just wondering what fuel injector cleaner you guys use and how often do you use it.
Thanks.
Old Feb 26, 2005 | 08:32 AM
Default RE: What Fuel injector do you use?
This is what I use now: http://lubecontrol.com/ (FP60) but Chevron's Techron is among the best for over the counter purchase. Fuel Power is added to every tank @ 1ounce per 5 gallons. I used Techron roughly every 3000 miles or if I noticed a rough idle, whichever came first. For the Techron get the large bottle that treats 20 gallons, pour it in and fill 'er up!
The Fuel Power is more than just a cleaner. Many people enjoy higher miles per gallon with use. Our '03 Corolla gained 2.5 MPG over several tanks and is now consistant at that level. My '04 Accord 2.4 5 speed manual gained 1.5 MPG after two tanks of fuel and is now constant at that level.
Old Feb 28, 2005 | 01:04 PM
Guest
Thank you for the information. Question, by using these products, does this eliminate having to have the injectors cleaned periodically by a mechanic (assuming rough idle/decreased fuel mileage, etc. is not a factor)?
Old Mar 1, 2005 | 03:18 AM
Hi Again..
I personally use Lucas Products for my cars..they have about 20 different products on the market and most of their products seem to work very well. I add about every 5,000 miles on the injector fuel...
Now you have more porducts to research...
Old Mar 1, 2005 | 07:02 AM
I have never had to take a fuel injected car in for cleaning/flushing so the answer is yes. By keeping the injectors clean there should be no need for other servicing.
Old Mar 1, 2005 | 05:44 PM
Guest
Thanks again-it's nice to have someone reccomend products they have used with success-I will check these products out.
Old Mar 1, 2005 | 09:39 PM
Lucas products are world wide and universally accepted. They make a terrific fuel system cleaner.
thunder_x
Sep 5, 2007 07:31 PM
thunder_x
Sep 9, 2006 05:18 PM
bobs87
Feb 14, 2006 05:48 PM
FlyLow
Dec 4, 2005 10:45 PM
dinzer
Aug 9, 2005 11:17 AM
