South AR, LA, MS, KY, TN, AL, GA, FL, NC, SC, WV, VA, DE, DC, MD
2002 Accord Engine Idle Problem
Old Mar 17, 2009 | 05:29 PM
steve931
Default 2002 Accord Engine Idle Problem
O2 Accord engine idle from 600rpm to 1200rpm any suggestions will be greatly appreciated. Steve931
Old Mar 18, 2009 | 12:45 AM
Could use a better description...
Old Mar 18, 2009 | 07:03 PM
steve931
Four cylinder automatic w/air
Old Mar 18, 2009 | 07:45 PM
Haha, okay I guess.
Does it go up and down between 600 and 1200 RPM? Like a pulsing up and down?
Most common problem is a clogged IACV (IDle Air Control Valve) on the back of the intake manifold. It can be taken off by removing the two 10mm bolts holding it on and the 2 coolant hoses running to it. Clean it with carb/intake cleaner and clean the carbon crud out of the ports on the intake manifold.
Old Mar 19, 2009 | 04:53 PM
steve931
Thank you very much for your time. I am a heavy equipment mechanic so I am a little lost on some of the automobile problems. This sounds like the fix I will try this and let you know. Again thank you. Steve 931
origami
Oct 26, 2019 01:24 PM
StatzFinest
Feb 10, 2008 11:32 AM
92Inspire
Aug 13, 2006 03:37 PM
ferry
Jun 13, 2006 10:09 AM
