Rear bumping noise
Old Mar 14, 2005 | 10:19 AM
dkgruv
Default Rear bumping noise
I have a 98 Accord with 100K Miles. Last 10,000 miles I'd been hearing more and more the bumping noises mostly over small bumps at 30 MPH or less. I found that it was the rear sway bar brackets. The rubber bushing was worn and allowing the bar to bounce. I removed them and applied electrical tape around the bar then installed the old ones back on to make sure that was the noise. That did it. I'm not into hacking and I will replace the rubber bushings soon. I could hear the noise by shaking the bar from under the car. It is two 12 mm bolts holding the brackets on. Easy fix!
Old Apr 18, 2005 | 12:15 AM
Evlampius's Avatar
Default RE: Rear bumping noise
duh!
thanks for sharing!
Old Apr 22, 2005 | 02:24 AM
Don't wait very long to replace those, your rideing around in a semi dangereous situation there.
The longer you wait the worst your cars gonna get...
By the way .. Welcome to the forum...
[IMG]local://upfiles/22/72C4A51E51384EA696726A92253C4A35.gif[/IMG]
Old Apr 26, 2005 | 11:45 PM
Evlampius's Avatar
ok - but better replace the bushings
Old Jun 10, 2005 | 07:22 PM
accordlowered04's Avatar
i wouldnt wait long to replace it. let us know how it turns out when you replace it. also welcome to the forum. hope you enjoy your time here.
stockxplorer
Sep 25, 2022 04:15 PM
micfly83
Nov 24, 2006 12:11 AM
XONE
Jul 29, 2006 02:43 PM
FlyLow
May 8, 2006 06:00 AM
atwood
May 1, 2006 08:59 PM
