97 accord check engine light
Old Apr 26, 2009 | 10:06 PM
n calif honda
Default 97 accord check engine light
check engine light comes on intermitently code says misfire #1 cyl. New plugs and wires checked valve clearance and still same code moved injector to #4 cyl and moved new plug and wire still shows #1 cyl misfire. checked crank sensor thier ok any suggestions
Old Apr 27, 2009 | 02:04 AM
Maybe replace the distributor cap and rotor.
Old Apr 27, 2009 | 08:31 PM
hondadude's Avatar
Does the code recur as soon as the key is turned on, or maybe after the engine has warmed up and been driven XX miles?
I'd say a real scan tool is needed to be able to get a "Freeze Frame" so you can find out Exactly what is causing the code.
Old Apr 30, 2009 | 04:45 PM
n calif honda
cap and rotor was replaced with tune up code recurs after driving variable distances always number one cyl
Old Apr 30, 2009 | 06:02 PM
The only other options are the injector resistor, the wiring/connection to the fuel injector. Valve clearance. Compression.
Old Apr 30, 2009 | 06:24 PM
,valve clearance, compression, also chk to make sure that the cam lobe is not worn down .. also believe it or not i had a egr valve once causing a 1 cyliner misfire
Old Apr 30, 2009 | 07:02 PM
If the EGR manifold was blocked on 3 ports and only the #1 port was open, there might be too much EG at times leading to a over-lean miss. Clean the EGR manifold and ports.
Old Apr 30, 2009 | 07:03 PM
n calif honda
disconnected egr valve and now no #1 misfire so it must be egr then?
Old Apr 30, 2009 | 07:07 PM
Yes, pull the EGR manifold, clean manifold, and clean the 4 ports into the intake manifold. Don't enlarge the ports w/ a drill bit as they are different sizes to achieve correct EG flow.
Old May 24, 2009 | 12:46 PM
n calif honda
thanks cleaned egr 3 clogged problem solved
