RSX Wheels on Accord?
Old Mar 17, 2005 | 12:41 PM
Peperoni Nose
Default RSX Wheels on Accord?
Hi,
Does anyone know if the 16" wheels from an RSX will fit on a 2001 Accord Coupe V-6? I was looking on ebay and saw a set of RSX 5-Spoke 16" wheels in chrome that would look sweet on my Black Coupe. But I'm not sure if the spacing on the lug pattern is the same and if the offset of both wheels are compatiable.
Has anyone tried RSX wheels on an Accord Coupe? If not, can anyone reccommend a 16" or 17" chrome wheel that looks good on a Black Accord.
Thanks,
Old Mar 17, 2005 | 05:02 PM
2000Ex's Avatar
Default RE: RSX Wheels on Accord?
Just look to see how many lugs there are. Your accord Has 5.
Old Mar 18, 2005 | 12:01 PM
remington870_20ga's Avatar
I dont see why it wouldnt fit.
Old Mar 18, 2005 | 04:28 PM
Patrick's Avatar
i know that HMC has changed their setup on wheel bearings over the last few years, so it very well be a bolt pattern fitment issue...i would try to find out the pattern size of your ride, then the pattern size of the RSX...
Old Mar 19, 2005 | 12:21 AM
Peperoni Nose
Thanks for the info guys. I managed to find out that a neighbor has an RSX and measured the distance on their bolt pattern and it is the same! Still don't know about offset, but I really can't imagine that it would be too much difference between them. Anyone know for sure? The ebay seller lists the offset as "45."
If my wife allows me to get them I will post a picture. May have to buy her some "bling-bling" so I can have some of my own.
Old Mar 19, 2005 | 11:39 AM
Patrick's Avatar
do you want to know how to measure your offset? i can help with that too if youd like...its Very easy...
Old Mar 19, 2005 | 01:41 PM
[sm=helpout.gif] Has Arrived..from WheelBrokerAng...
This is for the record...your 2001 Accord uses a 5 lug 115mm bolt pattern for the V6 engine.
The ACURA RSX (which has great looking stock wheels) has the same bolt pattern as your Accord. The offsets will both work on both cars as long as your Accord has the V6 engine.
I have been putting a lot of 18" wheels on both of those model cars and have also been putting on 18"s , 19"s and 20"s in staggered fitment sizes also (bigger tires on the rear) which gives the cars an Awesome Look and a very stable ride.
Check out a picture of a wheel that would look great on your Accord.
I hope this information helped you out...
[IMG]local://upfiles/22/410B032BB8AF4DDD92CEFEA0C9DA5376.jpg[/IMG]
Old Jun 6, 2005 | 02:17 PM
Gummi_67's Avatar
Check the offset etc.
I have a 04 Coupe and my brother has an RSX type S. Our wheels are interchangeable no problem. I'd say they'd fit without a doubt. Make sure you use the tire calculator when selecting rubber.
Old Jun 6, 2005 | 06:11 PM
Shocker's Avatar
The offset doesnt play affect with the bolt pattern the offset is the lip that is around the rim like on the inner side ....
Old Jun 7, 2005 | 02:18 AM
theycallmerickjames's Avatar
what is the bolt pattern on my 2005 accord v6 coupe?
