aftermarket header trouble
Old Oct 7, 2009 | 02:47 PM
daytonLSC's Avatar
Default aftermarket header trouble
Whats up guys,
So I just put on a new set of 2" headers stainless. I could not get the old O2 out, So I drove it home and the check eng. light was on, NO BIGY I have no O2 sensor in, then so I bought a new one. put it in. unplugged battery. plugged it in. then drove it NO LIGHT 50 min later light came on!! So I replaced the air filter. same steps with battary. and lights still on.
could the O2 go bad already? or something more?
Note: car has over 200k and I'm just trying to make it run good. I'm not trying to race it on the weekends. I put new heads on cause the old ones rusted out and had holes in them. I also deleted the CAT.
Old Oct 7, 2009 | 05:40 PM
Get the code scanned. Is this header on a go kart? What Accord is it?
Old Oct 7, 2009 | 07:32 PM
jason.sloan0519's Avatar
Probably a p0420 code from deleting the cat. Been having that problem myself. More than likely not an o2 sensor code that's gonna come up. p0420 is a bad cat code.
Old Oct 7, 2009 | 08:39 PM
daytonLSC's Avatar
hahaha its a go kart... JK its a 92 Accord LX, there for I cant get a CODE READING also I have not had a cat since it fell off a year ago, so I think its save to say thats not it. I have noticed that it ideals at 5000-4000 in Drive, also ideals at 15000 when its in N. Could that be the Rev limiter? and Would the rev limiter throw a code?
Old Oct 9, 2009 | 10:37 AM
its a 92 so does that make it pre OBD? if its OBD 1 you can go to autozone and they'll let you use a scanner for free but im not sure if your car is OBD or not.
Ill do some research on how to get a scanner for your year and model if its possible or not.
Old Oct 9, 2009 | 11:23 AM
Yeah your car should be OBD 1. Autozone or any autoparts store will let you use thier scanner for free but it has to be an OBD 1 scanner. It'll probably be a handheld tool that will only give you a code that you'll have to look up, just google it, probably be a p followed by a series of numbers. Let me know if you make any headway and if I helped at all.
Old Oct 9, 2009 | 11:31 AM
It's OBD-1 but you don't need a scanner. Jumper the SCS connector with a paperclip & watch the CEL flashing out the code. The DIY section has a link to instructions.
3wheelcaps
May 21, 2011 07:04 AM
thunder_x
Jul 12, 2007 09:37 AM
RTexasF
Mar 18, 2006 12:23 PM
RTexasF
Aug 18, 2005 10:55 PM
poff1986
Dec 19, 2004 03:25 PM
