Timing recommendations for stock 89 lx 5spd
Old Oct 17, 2009 | 08:15 PM
ohanahorse's Avatar
Default Timing recommendations for stock 89 lx 5spd
Hi, what's the timing to be set at for a 89 LX 5spd...and what vacuum line should be disconnected to set?
Old Oct 29, 2009 | 12:58 PM
hondadude's Avatar
When you pull out the little plug, you can rotate the crank till you see the timing marks on the flywheel. The center mark of the 3 that are close together. [RED mark]
If you unplug the vacum advance line, the timing should show the TDC [WHITE mark]mark.
For more low RPM power retard the timing a couple degrees; or for higher RPM power advance a couple degrees.
bpo145
Aug 4, 2006 08:17 PM
sir_nasty
Jun 14, 2006 11:28 PM
nixalot
Apr 20, 2006 07:38 PM
dinzer
Sep 6, 2005 01:04 AM
dinzer
Aug 7, 2005 03:26 AM
