Valve cover oooppppsss!
Old Oct 22, 2009 | 06:04 PM
KevinAccord's Avatar
Default Valve cover oooppppsss!
So I was minding my own business dismounting the front bumper to put on the front lip and i noticed that one of the screws of the valve cover was leaking some oil. so i went and purchased the little rubber o-ring(?) that goes in the middle of the screw and changed it. when I was putting the screw back on I noticed a little "crack" sound... yes, i broke the screw inside the valve cover.... crap... well, i'll get to it tomorrow.
Any one knows a good extractor brand? i used to have a craftman one but it broke and i don't know where I last store it...
Old Oct 22, 2009 | 07:03 PM
Lightbulb Hi Kevin
AutoZone sells a good low cost set made by Great Neck...about $26.99 for the set 5 pcs I think..
Old Oct 22, 2009 | 07:20 PM
How about using a dremel cutoff wheel and grind a slot for a flat screwdriver, then heat up the cylinder head around the bolt and screw it out?
Old Oct 27, 2009 | 11:07 AM
actually, it's not a good idea, since there's oil around and i might overheat a surface and bend it.
i listened to ang and the car is ready now... thanks to both of you guys.
The set was around $42.93 here but i had the $20-off for the card...
03Sleeper
Jun 11, 2008 08:54 PM
HondaLawgik
Jun 24, 2006 09:41 AM
projectaccord96
Apr 7, 2006 10:14 AM
LinX
Mar 4, 2006 03:03 AM
lightshow
Jan 11, 2006 11:49 AM
