f23a leakdown test, air leaking thru intake valve
Old Nov 16, 2009 | 09:46 PM
zeroice's Avatar
Default f23a leakdown test, air leaking thru intake valve
Hi there,
I'm going to blabber a bit about my woes and use you guys as my sounding board. Hope I find a good audience that may give me some decent feedback...
Here goes:
My 98 accord engine is kind of dying (low compression on cyl. 4) so i picked up a salvaged motor from a fellow via craig's list for a few bucks. (now i'm thinking I should have got the other motor from the other guy...)
I was going to service the engine before i dropped it in, like do the timing belt, h2o pump, etc.
Well, i did a health check by testing the leak-down. Cyl. 2 and 3 are leaking air via the intake valve . I can hear and feel air hissing out. Leakdown gage was reading something like 80psi on tank side, 15psi on engine side. However, cyl. 1 and 4 were reading about 100psi on tank side and 95psi on the cylinder side with little hissing. I never used a leakdown gage so I'm not sure this is right. I will say that this engine is on a bench so its cold.
Current timing belt is secure so i'm sure the pistons havent hit the valves and bent them.
I noted a few other visual clues:
- Drained oil, it was nice and clean; dark but clean and transparent, not opaque or sludgy.
-The h2o pump inlet and engine head h2o outlet are suspect of something contaminating it. There appears to be foamy oil/antifreeze mixture. Did it overheat and crack the head or cylinder block? But the oil drained clean... Anyone got an opinion?
I wonder what is causing the leak through the valves? Could they be bent? Could the head be cracked or warped?
I already ordered head bolts and a top end gasket kit so thats on the way.
I guess I have to open up... Tomorrow my friend will come over an verify the leak-down readings with me. I should open it up and measure the head for warpage. I dont have a run-out gage, so I wonder how I can measure and see if the valves are bent.
BTW, does anyone know where I can buy replacement OE style valves at a reasonable price (something reasonably below dealer cost)?
Oh, I'm a motorcycle guy roadrace a CBR600RR so I'm not too familiar with the car suppliers.
Thanks for being a sounding board o'might message board!
-Krishna
Old Nov 17, 2009 | 07:21 AM
Just to rule out something easy, check the valve lash. Too-tight valves are a possible reason for leakage through intake valves, although (unfortunately) that's a long shot.
Old Nov 17, 2009 | 08:45 AM
zeroice's Avatar
I did check the valve lash and there should be sufficient clearance. I didn't measure it, but there was clearance as I could feel the rockers rock.
scjfly
Jun 29, 2011 01:48 PM
petef23a
Dec 14, 2009 08:23 AM
hpsmax
Sep 30, 2009 04:22 PM
hpsmax
Sep 30, 2009 04:18 PM
Aug 9, 2006 12:34 PM
