Any DIY or instructions for changing transmission fuild on 2003 manual Accord?
Old Nov 16, 2009 | 10:07 PM
alpac's Avatar
Default Any DIY or instructions for changing transmission fuild on 2003 manual Accord?
Hi Guys,
Is there any DIY or instructions for changing the transmission fuild on a 2003 manual Accord? My 2003 Accord with 80k miles starts being rough when changing gear particularly when cold.
Al
Old Nov 17, 2009 | 12:46 AM
Talking Hi Member
Did you try doing a Search on the subject in the search area yet..Try it 1st...
And here's your state flag as a present...Enjoy
Attached Thumbnails Any DIY or instructions for changing transmission fuild on 2003 manual Accord?-northcarolinaflag.jpg
Old Nov 17, 2009 | 01:17 PM
I didn't find one, so I just wrote one...
https://www.hondaaccordforum.com/for...d.php?p=189206
Unfortunately, the parts drawings don't have a clear view of the fill & drain plugs.
Old Nov 17, 2009 | 10:32 PM
alpac's Avatar
Thanks Jim, exactly what I was looking for.
Old Nov 17, 2009 | 10:45 PM
alpac's Avatar
I did search the subject first yes and found nothing on manual transmission. By the way I happened to be a major contributor on another car forum for my other car and have been for many years. I have helped a lot of newbies, people who are like me on this Honda forum, who need a little information or help that can make their life easier. I never answered by "Do a search".
Thanks for the flag though
Old Nov 18, 2009 | 10:27 AM
Lightbulb I See
Maybe YOU should ask some of your newbies to do a search then.
We find that a lot of the questions Newbies ask are in the search forum, that is why we ask that question.
Some of us on here have done a lot of posting to many subjects and have spent countless hours doing so only to be asked the same question over and over again that Was in the search forum....
And your welcome on the flag I posted for you , I even have taken the time to take and individually store 60 flags to use on all the forums that I mod on so that I can send them out to New Members as a Welcome.
Attached Thumbnails Any DIY or instructions for changing transmission fuild on 2003 manual Accord?-i..angelo.jpg
Old Nov 18, 2009 | 12:00 PM
alpac's Avatar
As I said I did a search and did not find anything on this. By the way here is my first participation to this great site. https://www.hondaaccordforum.com/for...ad.php?t=29248
Old Nov 22, 2009 | 01:38 PM
alpac's Avatar
Just changed the manual transmission fluid this morning. Easy job indeed, 50mns all together and taking my time. Thanks to Jim for the instructions that helped me locating the drain and fill plugs. Changing gear is still pretty tough. It is not the synchros as double clutching does not help. Wondering what that could be.
Old Nov 25, 2009 | 08:41 PM
alpac's Avatar
Quick update on the issue. It turned out that the problem came from a leaking slave cylinder. Since changing the MTF did not make any improvement and the clutch was not slipping I eventually suspected the clutch hydraulics circuit. A clue about a possible problem with the hydraulic was that the gear switching was very tough at start but got better after some time using the clutch. Same thing as when you have air in your brake circuit and the brake get better after pumping. I inspected master and slave cylinders last Monday and found out that the slave cylinder was leaking pretty bad. I brought the car to a nearby indy this morning pointing them to the leaking slave cylinder as the possible cause of hard shifting and Bingo! They replaced the slave cylinder and $250 later everything is fine now. With the slave cylinder replaced and the MTF I changed myself with Pennzoil Synchromesh MTF switching gears has never been that smooth. Thanks again for the DIY instructions for replacing the MTF :thumbup:
JimBlake
DIY Answers.
Apr 26, 2013 01:34 PM
markus9175
Mar 27, 2009 10:35 PM
silverstreak89
Aug 17, 2006 11:30 AM
tiffany
Apr 29, 2005 07:17 PM
