01 16" tire sizing??
Old Nov 17, 2009 | 08:53 AM
Busareds's Avatar
Default 01 16" tire sizing??
Here's the deal...........
Have a 01 4dr EX-L that has two center bent wheels...........
Also have in my shed a set of 03 V6 coupe OEM wheels and tires with less than 10K miles on them.........
So my thinking was to buy a set of 16" wheels for my 01 and use the tires from the 03 wheelset. They are the factory 205/60-16.
My thinking is that it will also give me a lil fuller look in the wheel well, a better ride with a bigger diameter tire, and a little larger contact patch on the road.
Will there be any clearance issues?
I am doing this to save a little cash and use some tires I already have. This is my daily beater car with 175K on it and no problems at all. Everything still working A/C, ABS, SRS, etc...........
Car is silver, and looking to get a silver painted 5 or 6 spoke wheel that is rather cheap, have found one wheel so far for 91 each.........Sport Edition F7 16".
Old Nov 17, 2009 | 03:57 PM
Question Question
What is the bolt pattern for your 2001 wheel and then what is the bolt pattern on those 2003 wheels
Old Nov 17, 2009 | 04:36 PM
I think 2001 4-cyl cars had 4-bolt wheels.
If your 2001 has a V-6 and 5-bolt wheels, then they might bolt up directly...?
Old Nov 18, 2009 | 06:58 AM
Busareds's Avatar
the issue is with the tires fitting, not the wheels........
the wheels from the 03 are 5 bolt and my 01 is a 4 cyl with 4 bolt........
I just want to know if the larger tire 205/60-16 will fit ok if I buy a set of 16" wheels in 4 bolt pattern to put on the 01
Old Nov 18, 2009 | 08:52 AM
I think the 2001 V-6 came with 205/65-15.
So those 205/50-16 tires are barely 5mm larger in overall tread diameter. I bet they'll work OK.
Old Nov 18, 2009 | 09:47 AM
Exclamation They should fit
The difference is minimal..
2001 OD of tire is 24.9
and 2003 is 25.7
Juice_2469
Apr 2, 2015 11:20 AM
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
