timing belt noise?
Old Nov 18, 2009 | 07:39 AM
jrk_
Default timing belt noise?
I just got a timing belt put on a 99 Accord lx coupe 4cyl. now the belts make a whistling, whining kind of a noise, it's the loudest when at idle.The engine seems tight but does run ok.
I took it back and was they heard the noise and said its is from the timing belt but there is no adjustments because it is auto-tension system. over time the belt will stretch and the noise should stop.
That doesn't sound right to me? any one know if there is a way to adjust the belt thanks for your help JIM
Old Nov 18, 2009 | 08:47 AM
The belt is not auto-tensioning.
The belt-tensioning spring only acts during the adjustment process, then you tighten the tensioner-lock-nut to lock the tensioner in position. Did you have this done at a shop that knows Hondas?
However... It's not real unusual for a new belt to whine a bit at first (depending on how loud it really is).
Old Nov 18, 2009 | 09:28 AM
you might want to ask them how they adjusted the belt ,, and,, also if they left a 10mm bolt installed on the tensioner ,,,,,,,,,was this a Honda shop ?? dealer or specializing in Hondas ??
Old Nov 18, 2009 | 11:15 AM
jrk_
Thanks for you imput JIM
Old Nov 18, 2009 | 09:11 PM
hondadude's Avatar
I'll place my bet.......
The counterbalance belt is too tight.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
