Starting and electrical problems
Old Nov 18, 2009 | 11:59 AM
swano586
Default Starting and electrical problems
Hi, I have a 1997 Accord. My car turns over slowly, but starts. I started noticing this problem when I put a new battery in only a year ago. Also at this time, my rear defrost, interior overhead light, and the slowest setting on my windshield wipers stopped working (all at once). I checked all of the fuses and none of them were blown. I have seen some threads recommending checking the relays. How do I go about doing this? A mechanic told me that my starter is probably bad, but I have reason to believe it might be an issue with my battery. What do I do if my battery is putting out enough cranking amps?
Any advice/ troubleshooting help would be much appreciated.
Thanks!
Seth
Old Nov 18, 2009 | 09:02 PM
hondadude's Avatar
Check battery connections and the grounds from the neg battery terminal, then for the rest of it , you'll need an ETM to see the different circuit schematics.
Load test the battery just to be sure it's okay.
Usually a bad starter windings will crank slower when the engine/underhood is hot.
smgray
Sep 7, 2013 04:42 PM
erader00
Sep 24, 2012 11:36 AM
Too Many Hondas
Nov 8, 2010 03:44 PM
Jonny.the.Canadian
Aug 25, 2008 01:10 AM
dude9571
Feb 11, 2006 12:17 AM
