gas line "pipe" under 94 accord
Old Nov 18, 2009 | 03:59 PM
md2020's Avatar
Default gas line "pipe" under 94 accord
Can anyone tell me the size of gas line on my 1994 accord? I need to get the correct sized along with some compression fittings to repair the rusted leaking old line.
Thanks,
marty
Old Nov 19, 2009 | 08:35 AM
md2020's Avatar
Default new lines
After looking closer I'm planning on getting replacement fuel lines. As you know there are 3. One is a feed, one is a return, and one is a vent. I'm trying to get by as cheap as possible because I honestly don't know how much longer the car will last. They all look very corroded, and the feed is defintely leaking. So being the cheap a** that I am I thought I'd try getting by with just replacing the feed and the return lines since the vent line is over $80
Any thoughts?
If its truley just a vent could I use some cheaper tubing, cut out the bad part and replace it with with some pipe clamps?
Let me know.
Thanks,
Marty
cavemantitan
Jun 5, 2013 12:19 AM
eduard
May 9, 2013 12:11 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
