panel stuck at door
Old May 1, 2006 | 05:09 PM
tbopha's Avatar
Default panel stuck at door
I've freed the panel around the inside edges, but something is holding the door by the handle. Whats holding it in and how do i free it up on a 99 accord.
Old May 1, 2006 | 05:15 PM
Default RE: panel stuck at door
I'm assuming that you either missed a screw underneath the armrest (goes through the armrest and looks as if it holds the armrest to the door but it doesn't...) or there is just a plastic clip there.... Most likely there is a screw that goes down inside the "hand hold" in the door and has a plastic piece in there that needs to be popped out then the screw removed... can you take some pictures if this doesn't work?
Old May 1, 2006 | 05:48 PM
tbopha's Avatar
I took some pics but the files are too big to send over this program. Do you have e-mail account beside this one. this one only allows 500k. My pics are 1m and greater.
Old May 1, 2006 | 05:49 PM
I just PM'd you my e-mail address go ahead and send them there...
Old May 1, 2006 | 05:50 PM
tbopha's Avatar
arm rest screw is removed and screw by handle.
Old May 1, 2006 | 06:06 PM
alright I'm guessing that your door handle is the hangup... what you need to do is pull that door handle out slightly and you'll notice two things, one there is a metal piece that goes into the handle (that opens the door) on the inside and is held in place by a clip, remove that and disconnect the power wires going to your door lock switch...
I'm almost positive that's what you're fighting...
Option 2: that door handle (with the power lock switch) will rotate slightly and slip through the door panel if you like... then lift the panel up/off while sliding it through.
[IMG]local://upfiles/3079/B73502E4F1574F48A3D2DA5CDB2024B5.jpg[/IMG]
[IMG]local://upfiles/3079/9564998DAF36449F8F4770A2747E57F9.jpg[/IMG]
Kelsen
DIY Answers.
Apr 7, 2020 11:46 PM
vteck2001
Jan 13, 2013 01:46 PM
sona1111
Dec 3, 2012 06:09 PM
zerodoubt
Jun 22, 2006 08:15 PM
ryan ortego
Dec 4, 2005 04:10 PM
