HID Prob
Old Dec 21, 2009 | 01:29 AM
Fender5's Avatar
Default HID Prob
I have the projectors from ebay. Can't go back to stock now, since i accidently broke one of the stock ones. But i got a H3 kit from Ddmtuning and it won't work still. (I could never get the 9006 HIDs to work either)
http://i247.photobucket.com/albums/g...5/SD533123.jpg
Where do those wires plug in? They do not fit the stock oem connector. I tried
I just ordered a wiring harness so maybe that might help]
I did search a bit on here as well
Old Dec 28, 2009 | 07:52 AM
aiden's Avatar
I believe you bought the wrong HID kit. You said you bought H3 kit, while you're trying to get the 9006 bulbs to work. You should have bought the 9006 kit not the H3 kit.
Old Dec 29, 2009 | 01:08 AM
Hmm... last time I used those connectors was on a Volkswagen. I believe I shoved them into the bulb connector. You should only need to plug in the 9006 connector on the ballast to the original headlight bulb connector. I think the polarities are reverse for some reason on the 94-97 Accords so you might have to mod and flip it. You could PM 19Accord97 or live2rice, they both have 94-97 Accords with the DDM kits.
The kits are all universal, all bulbs have the same connector to the ballast and a 9006 connector from the ballast to the headlight harness.
Old Jan 9, 2010 | 12:03 AM
Fender5's Avatar
my bad i meant I have the H3 kit because I did a housing swap to the projectors which have the H3 kit
But i tried the 9006 kit whenever I had the stock housing
The only problem is the two wires.
Old Jan 9, 2010 | 01:20 PM
19Accord97
You shouldn't need those....
Well I think you need one for the ground which is right next to the headlight socket. Other than that it is plug n play. However, you might have to reverse the plug that goes to the oem plug socket.
Old Jan 16, 2010 | 11:01 AM
humblehyper's Avatar
I bought a 6000k 9006 kit and I have a small problem. When the light turns on and while driving it flickers just a little bit, I can see the beam in front of me going up and down. I don't have fog lights and I also bought those relay harness.
What could be the problem? Bad kit? I bought this http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Jan 12, 2011 | 03:33 PM
kevinsyfers's Avatar
If its a little flicker that you can notice on the wall just small shaking it looks like its the ballast. The ballast you have is a DC standard ballast to solve this issue your gonna need to order AC ballast's these Slim Ballast are AC that should solve the problem. http://www.hidnation.com/hidballasts.html
An D. Nguyen
Aug 13, 2013 09:59 PM
RebelK2
Jan 21, 2007 10:58 AM
DSMtraitorPhil
Aug 2, 2006 02:02 PM
cidster
Apr 13, 2005 10:20 PM
dubinov
Apr 6, 2005 05:42 PM
