HOW TO... Fix Stripped Leaky Oil Pan Plug
Old May 12, 2006 | 12:08 AM
Default HOW TO... Fix Stripped Leaky Oil Pan Plug
this will permenantly repair the oil drip issue from the oil pan plug after it has been stripped,,The dealer will charge you $ 300 or moe to replace oil pan and labor, using this kit , there is no need to replace the oil pan.
You need a time-sert kit # 1415 you can get it from Matco tools or directly form timesert..
inserts 14 by 1.5
all the instructions will be included in the kit..
you also need a permanent oil valve , it is spring loaded, so you never have to remove it,, you can get the valve at,,,
http://www.fumotovalve.com/ ....or 1-425-869-7771.... the valve you need is F-106..
i have done dozens of these and they work great, you can also install these instead of the regular plug ,don't wait till they get stripped thus avoiding future complications,, especially if you take the car to those quick lube places..
http://www.timesert.com/html/mtrcsert.html ,go to this site to see what the kit looks like , it also has video instructions , download it and watch it
Old Aug 26, 2009 | 11:03 PM
jdrake4
Looking at the time-sert kits I am not sure which one I need. The dealer informed her that they just used an oversized bolt and it will only last for 1 or 2 oil changes. She was quoted $600 to fix the pan.
The car is a friends I am trying to help out so I haven't seen it yet.
She has a 2002 Honda Accord LX with V-6.
The time-sert lists two kits
1415C - M14x1.5 9.4mm length "for aluminum pans"
1485C - M14x1.5 REDUCER reduce size from M14x1.5 to an M12x1.5 This kit is for a Tin Pan--not aluminum. It says it cannot be used if an oversized bolt was already used
Any idea if the pan is aluminum or the tin/steel?
I found the oil pan on line part number 11200-P8A-A00 for about $75. I was trying to avoid pulling the pan, but I am thinking I might have to now cause to me $75 seems cheap for an aluminum pan.
I am also thinking of having a friend weld a slug onto the old pan so we have real threads to use!
Thanks in advance for the help!
Old Aug 27, 2009 | 09:30 AM
it is aluminum,, you got the correct part # it costs around $ 110 at the dealer .. so $ 75 might be right
Old Sep 16, 2009 | 12:17 PM
hondadude's Avatar
If you have the time, and equipment.........
I used to drop off the oil pan and use a bolt and with nut on the inside of the pan.
draw down the nut tight and tack weld it in place.
However I've had good luck with timeserts as well
devinzmax
Oct 8, 2014 06:49 PM
deserthonda
Oct 22, 2011 11:30 AM
xBlack
Mar 13, 2011 10:02 AM
greg9442
Oct 15, 2009 10:37 AM
jon02accord
Mar 26, 2008 10:54 AM
