Water In Trunk ,,,,,FIX ,,,accord 90-97
Old May 12, 2006 | 03:06 AM
Default Water In Trunk ,,,,,FIX ,,,accord 90-97
The most common cause i have seen for water accumulating inside the trunk , is the outer tail lense gasket
these gasket are made of a foamy rubber material, over the years , they get hard and crack , when that happens , after a good downpour you might find water in the trunk..
replacing these gaskets is real simple
parts needed :2 gaskets, honda-bond or rtv silicone
90-93 accords,,part # 33503-sm4-003
94-97 accords,,part # 33503-sv4-ao1
you will need two ,they are the same for either side,,
tools needed : 1/4 inch 8 mm deep socket, small extension, rachet, i would not use anything bigger than 1/4 inch , a bit too much force and you might snap the stud in the lense
remove the panel covers, Disconnect the connectors that are plugged into the tail lense, remove the 8 mm nuts, remove tail lense,
Clean the area real good where the gasket will meet the body of the car, apply some honda-bond ( silicone ) where the gasket will meet the body, reinstall tail lense assembly..
DO NOT overtighten the 8 mm nuts as they will snap easily..plug the connectors back and you are done,
Always chk your work, make sure all the lites back there work properly..
wayland
Aug 13, 2016 10:19 AM
erikhans
Sep 11, 2013 06:48 PM
thaison86
Jun 28, 2012 12:03 AM
imabadczech
Dec 1, 2010 06:41 PM
Antarctica
Jul 5, 2008 11:54 PM
