ROTOR OVER HUB CONVERSION
Old May 15, 2006 | 07:26 PM
Default ROTOR OVER HUB CONVERSION
I HAVE NOT personally done one of these conversions as of yet, but i found these sites and i thought it might be helpful to someone who might be thinking about doing a conversion..
http://www.cb7tuner.com/vbb/showthre...ake+conversion
http://www.accordinglydone.com/forum...ead.php?t=3970
Old Dec 3, 2009 | 07:16 PM
Over the past weekend, I did the rotor over the hub conversion and thought that I would post about my research for the 94-97 accord sedan/coupe 4-cylinders.
I cross-referenced parts based on part numbers from aftermarket suppliers, because OEM part numbers between Acura and Honda may be different.
The 98-99 2.3L Acura CL and the 94-97 2.2L Accord Sedan/Coupe have some identical parts on the front of the car:
Steering Knuckle (actually have the same OEM part numbers)
Lower ball joint
Wheel Bearing
Calipers
The only difference between the two front setups of the Accord and the CL is the hub and the rotor. Acura implemented a normal setup for their cars for the 98/99 CL, but used the Accord setup on the 97 CL.
I bought a 98/99 2.3L CL steering knuckle w/ hub from a U-Pull-It junkyard for $25 a piece. I replaced the lower ball joints then swapped out the entire knuckle to my car.
The rotors that you need to buy are for the 98/99 2.3 CL (which are identical to the 98-02 Accord 2.3L front rotors if you like buying Honda OEM parts).
All other brake parts (except for the hub and rotor) can be ordered based on your accord, because they are identical to the CL.
Old Jun 15, 2011 | 10:12 PM
Tek310's Avatar
so just to clarify..
all that is needed to complete this swap is CL rotors, steering knuckle, and hub assembly.
also if i read correct, the parts are specific to 4 cylinder and v6 engines. so if you have a 4 banger you get 4 cyl. parts. if you have a v6, you buy v6 parts
also here is the proper link to the accordinglydone.com site
http://www.accordinglydone.com/forum...hub+conversion
Old Jul 10, 2024 | 11:19 PM
Never saw this post. The knuckle is identical between the accord and the CL, so you don't need to swap hubs. I used the CL knuckle, because I didn't have the tools/skills at the time to remove the hub/bearing from the knuckle. All you need is the CL hub and rotor.
btartus
Nov 13, 2021 05:45 PM
Remus77
Mar 9, 2015 01:57 AM
96FiveSpeed
Feb 10, 2014 07:51 AM
2.2ex965spd
May 27, 2007 06:25 PM
fleetfoot
Mar 13, 2007 01:26 PM
