HOW TO,,,,CLEAR SRS LITE
Old May 18, 2006 | 05:24 AM
Default HOW TO,,,,CLEAR SRS LITE
(should work for all honda)
On every single accord i have worked it has been located under the dash, left side ,, it is a yellow ( SRS connectors are all yellow ) 2 wire connector,either ( gray..gray ) or( green ,, green ) on occasion it is a pain to locate it ,, but it is there ..
*tools- paperclip, flashlight , SCS connector ( if possible ) ,,most of you do not have the scs connector so just use paper clip
Once you find it,, jump the wires together, use SCS connector or , Insert paperclip ...
WHEN YOU DO THIS YOU HAVE TO BE FAST ON CONNECTING AND DISCONNECTING , whatever you use to jump the wires,,, if you have the SCS service connector it would make the job a lot easier..
Erasing the DTC memory/resetting SRS light
1) turn ignition switch off
2) jump the SRS ( MES) connector ( MES = Memory Erase Signal ,) using the scs connector or paper clip
3) turn ignition switch to on
4) The SRS indicator light will come on for about 6 seconds, and then go off. Remove the SCS service connector ( paperclip) from the MES connector within 4 seconds after the SRS indicator light went off
5) The SRS indicator will come on again. Reconnect the SCS service connector ( paperclip,) to the MES connector : within 4 seconds after the light comes on.
6) When the SRS indicator light goes off, remove the SCS service connector ( paperclip ) from the MES connector within 4 seconds.
7) The SRS indicator light will blink 2 times indicating that the memory has been errased/clear.
8) turn the ignition switch to off and wait for 10 seconds.
it should be cleared.........If not repeat the procedure.......
Hope this helps some of you...
1lowcaprice
Feb 9, 2009 03:26 PM
blackex19
Oct 7, 2008 12:57 PM
zoominhuman
Nov 19, 2007 10:28 AM
steviebix
Aug 16, 2007 01:54 AM
LPlum
Sep 21, 2006 06:55 PM
