Battery Going Dead ?? CHK For Draw
Old May 18, 2006 | 12:32 PM
Default Battery Going Dead ?? CHK For Draw
first off , is the battery ok ?? does it hold a charge??
to test for parasitic current draw, set up the multimeter to ammeter. disconnect the neg battery cable and hook 1 lead to battery , the other to the cable, ..
if there is a draw of more than .030 amps , start pulling fuses 1 at a time till you find the circuit with the draw in it ..
if your car has shoulder belt retractor, you need to wait about 3-5 minutes for the timer to shut off, othrwise you get a false reading..
also make sure everything is turned off,
Once you find the system causing the draw , then you have to diagnose which part of it, is causing the problem
http://www.in.honda.com/Rjanisis/pubs/SN/A020900.PDF
I found the above link. it has pics , you will need ADOBE reader on your computer to view it
rampcrawler
Aug 7, 2012 04:09 PM
mgamer20o0
Feb 3, 2010 06:47 AM
fireballer44
Jan 21, 2007 04:23 PM
shaldar
Dec 13, 2006 09:55 PM
deserthonda
Jun 20, 2006 05:21 AM
