4 Lug Accord rims? will Civic rims fit?
Old May 19, 2006 | 04:23 PM
KevinFelt's Avatar
Default 4 Lug Accord rims? will Civic rims fit?
Are Civic and Accord 4 lug rims the same?
Where is a good place to look for factory alloy Accord rims?
Old May 23, 2006 | 03:28 AM
Default RE: 4 Lug Accord rims? will Civic rims fit?
Hi Kevin..Most of the civics in the 90's with 4 hole lug rims are 100mm and most of the Accords in the 90's that have the 4 lug wheels are of 115mm.
Tell me what you have in mind and I will help you get the right information..
Old May 25, 2006 | 06:12 PM
KevinFelt's Avatar
I have a 94 Accord and am looking for OEM 15" Alloys. What year range Accord rims will fit?
Old May 25, 2006 | 06:15 PM
KevinFelt's Avatar
I've seen some very nice rims on civics, that is why I wanted to know if they would fit.
Old Jul 24, 2006 | 03:27 AM
ACCORDRYDLX
it's universal
Old Jul 24, 2006 | 12:07 PM
incountry's Avatar
HONDA ACCORD RIMS HAVE A LARGER BOLT PATTERN THAN THE CIVIC, BUT ANY ACCORD RIM FROM 1990 TO PRESENT WITH THE 4 HOLE BOLT PATTERN WILL FIT, THIS GIVES YOU A WIDE VARIETY OF WHEELS TO LOOK FOR, SOME WILL BE REASONABLE AND SOME WILL BE TO EXPENSIVE, ALL ACCORD EX'S HAVE 15" RIMS, AND AFTER 1996 SOME OF THE SE"S ALSO WERE ALUMINUM
Old Aug 17, 2010 | 12:13 PM
David23's Avatar
Default Honda Rims????
Ok I have a 2001 Honda Accord Value Package with 14 inch rims and 4 lugs on it. I recently went to the junkyard and saw a 2005 Honda Civic with 15 inch rims also with 4 lugs on it can I switch the two????
Old Aug 17, 2010 | 05:18 PM
I'm pretty sure that even in 2005 the Civic 4-bolt rims have a smaller bolt-circle diameter.
Not until 2006 or 2007 when Civic went to 5-bolt that was the same as 5-bolt Accord.
Old Sep 9, 2010 | 01:40 AM
Hey everyone, did anyone notice that this post started back in 5/19/2006 ?
I just noticed it myself...
Old Sep 9, 2010 | 06:51 AM
Yeah, David23 must have found this thread by searching (like we ask everyone to do).
