Power Window acting goofy
Old May 23, 2006 | 01:42 PM
tbopha's Avatar
Default Power Window acting goofy
Since I replaced my actuator, my power windows move 50% slower. Then when I roll them up at the same time, the passenger side stops or stops and then rolls up slowly. I will first check the harness to make sure that no pins are loose and that my drivers side window is on its track since one of the side rail fell off as I was replacing the actuator. I did put it back but now the window makes a loud noise when it descends and a clank sound when it hits the bottom. I was also wondering if the problem could be something else like poor distribution of voltage? If some had this problem or knows how to fix it, please reply.
Old May 23, 2006 | 02:33 PM
Default RE: Power Window acting goofy
the actuator? you mean the regulator? did you buy one from honda? well if you didnt, its because that motor isnt as powerful as your oem honda one so it wont go up and down as fast.
but in all reality i think you have an adjustment issue the window can be adjusted left to right in the door at your discretion.
Old May 24, 2006 | 09:42 PM
pedroj
Default RE: headlights
i want to replace my head lights but i can not find instructions anywhere. help?
Old May 30, 2006 | 05:31 AM
tbopha's Avatar
Default RE: Power Window fixed
The battery was drained due to playing music with the door open while I was fixing my actuator. The car did not start the next day and had to be jumped started. Now everything works like it was new!!!
Old May 30, 2006 | 03:04 PM
Glad you got it fixed... a dead battery is a surefire way to have electrical problems.. *L* Glad it was cheap though!
Jak3l
Aug 7, 2015 10:23 AM
jkeely
May 2, 2012 03:48 PM
slayer712accord
Mar 26, 2008 09:29 AM
mmazb3
Nov 26, 2007 03:16 PM
phaders
Jan 5, 2006 05:17 PM
