2003 Honda Accord LX Not blowing air
Old Jun 17, 2010 | 11:13 AM
jefe86's Avatar
Default 2003 Honda Accord LX Not blowing air
Greetings all,
CAR: 2003 Honda Accord LX Sedan 4 cyl.
Here's the issue:
My fiance's car's A/C was working fine on her way to work and again at lunch, but then no air was blowing when she was on her way home. Not on heat and not on air conditiong. Not at all.
Since then I've checked the fuses (all were good) and bought a new blower motor (returned it since it was doing the same thing as the current motor).
FUSES: All the fuses were good, so I read more online and came to the conclusion that it was the blower motor.
BLOWER MOTOR: Switched the motor and it was doing the same thing as the original. When I go from IGNITION OFF to START (II), the Blower Motor jumps a quarter turn, but never comes on.
I've ruled out the resistor simply because none of the speeds work at all.
I've also performed the A/C Self Diagnostic which gave me 6 blinks which tells me I have an issue with the ECT (Electronic Coolant Temperature) Sensor.
Before I go out and buy this part and 'try it' out on the current ECT's (I saw there were two in this car), I wanted to know how this relates to the air not coming through the vents. I am a novice, but am a quick learner with a Chilton manual on hand.
Sidenote: When I turn on the car and press the button to turn on the A/C, both radiator fans turn on for about a second or two then right back off.
Any help would be greatly appreciated! Thanks!
Old Jun 17, 2010 | 01:43 PM
I think the blower control "resistor" isn't a resistor but a solid-state control for the motor speed. Just because you get no speeds at all I wouldn't rule that out.
Old Jun 17, 2010 | 01:48 PM
jefe86's Avatar
Well I didn't technically rule it out but maybe more of an overlooking it simply because no one has that part in stock and I don't want to be set back $70 or so for several days just to have the wrong part again. The blower motor set me back about $150 for 3-4 days only to find out it was never that in the first place.
I actually wanted to try it out, but for monetary reasons don't want to unless it's absolutely necessary. I'm also wondering why the A/C self-diagnostic (that I found here might I add) is telling me the fault is at the ECT sensor.
I'm clueless.
Old Jun 17, 2010 | 01:56 PM
I'll try to remember to look up in the Helm book.
The AC is controlled through the ECU, so if the engine coolant is too hot it'll cut back the AC to avoid overheating the engine.
Old Jun 17, 2010 | 02:00 PM
jefe86's Avatar
Thanks I would appreciate that.
Would this apply to the blower as well meaning it would cut it off completely even if the A/C itself is not running?
Old Jun 17, 2010 | 03:53 PM
Second thoughts... No I don't think that would apply to the blower. Just to the AC compressor.
Manual heater/AC? Or is it auto-climate-control?
Old Jun 17, 2010 | 03:55 PM
jefe86's Avatar
I'm a little vague on what you mean, but my Fan is controlled through a dial and I press a bunch of buttons to turn on my AC with vent control, defrost, etc. I don't have a setting to turn to a temp and it adjusts itself if this is what you mean.
Old Jun 17, 2010 | 04:00 PM
That is what I mean. My daughter's 2003 LX was like yours. I wasn't sure if automatic climate-control was available that year on LX.
Old Jun 17, 2010 | 04:02 PM
jefe86's Avatar
Ah okay. Glad we cleared that up.
Old Jun 17, 2010 | 04:26 PM
I found a thread from a different forum where the blower motor stopped running, and sounds like the problem you are having. Their solution was to replace the blower resistor.
The temperature sensor might not be detecting the proper air temperature and setting the code 6. The PCM will shut down the a/c to prevent damage.
Look in your Chilton's manual to see if there is a test on the blower motor resistor. Let us know what the test tells you to do.
The resistor is simple to replace, and I would try to find one at a junkyard.
