Still No Answer
Old Aug 10, 2010 | 04:00 PM
Hybridman05's Avatar
Banned
Default Still No Answer
Well, I've asked a local muffler shop owner to kind of check around to see if he knew of anyone who has tried turbo mufflers on an '05 Accord Hybrid 3.0, and he has yet to find out anything. He said he would check some more.
I guess there are few cars of this type and year on the road, so few, no one knows the answer to my search. If any of the few out there have tried this, I will probably never know if they had an improvement or not.
Time to give up I guess...
Old Aug 10, 2010 | 04:18 PM
g22cd5's Avatar
Supper Moderator
well why dont you try it and be the 1st to do it
Old Aug 11, 2010 | 09:16 AM
Banned
I may have to do that, g22cd5! I could be a trail blazer, and exhaust test pioneer! Scientists never know answers til they experiment!
Good suggestion- Thanks!
Old Aug 11, 2010 | 01:56 PM
g22cd5's Avatar
Supper Moderator
that's the spirit!!!
Old Aug 12, 2010 | 09:52 AM
I expect it to be a lot like a non-hybrid V-6 Accord of the same generation (2003-2006). But I don't actually know firsthand.
Old Aug 14, 2010 | 09:38 AM
Banned
Thanks Jim. I still haven't got nerve to try it. If it messes up the performance, I'm probably stuck. It's having a hard enough time performing good at all in this Texas heat. I've posted about this before both here and on another Honda forum I used to be on, but this is one "weather-moody" car. Lately, it feels like about 1/3 of the power isn't there. In winter, it runs like a souped V-8. I sometimes wonder if the climate in Japan is cold where they started Hondas, and they are built to run best in cold weather.
I've had the car checked time after time, and they never can find why it is this way.
Old Aug 15, 2010 | 09:34 PM
In this heat & humidity the AC is probably sucking a lot of power. That would be noticable in most cars. If you can tolerate this as a test, turn it off to see if that makes a difference.
I usually DO NOT recommend using higher-octane fuel, above what the owner's manual says. But the high temperatures might just get you there. Try a tank of the next-higher gas just to see if it makes any difference.
Old Aug 16, 2010 | 01:45 PM
Banned
It probably is reacting to the heat and humidity. Yesterday, it was running like a scared ape again. It will after the fuel gets down to around 3/4 of a tank, most of the time.
I'm using Shell 89. For a long time, the 91 octane was great on this car, but after it got more broken in, it seemed to not be as good as the 89. It's been a long time since I tried 91 V-Power, so I might again. It's in the shop all this week getting some body work done. Thanks, Jim.
Old Aug 16, 2010 | 02:18 PM
jdmjnky's Avatar
Youtube.com holds some footage of this I believe. Also you can check v6p.net IIRC it's been done.
morra1221
Mar 23, 2006 07:19 AM
eddieq19
Mar 15, 2006 11:49 PM
eddieq19
Mar 14, 2006 02:27 PM
Jan 15, 2005 06:14 PM
